Can I replace the wired virgin modem with a wireless one?
Old 16-07-2008, 9:03 AM   #1
2,136, Level: 10
Points: 2,136, Level: 10 Points: 2,136, Level: 10 Points: 2,136, Level: 10
Thanks: Gave 4, Got 7
Is it possible to buy a standalone wireless cable modem so that I only have to have one box plugged in?
Old 16-07-2008, 9:30 AM   #2
4,587, Level: 16
Points: 4,587, Level: 16 Points: 4,587, Level: 16 Points: 4,587, Level: 16
Thanks: Gave 135, Got 130
Re: Can I replace the wired virgin modem with a wireless one?
This is a good question, and I too would be interested in finding out if there is a wireless router solution for Virgin cable.
As far as I know there isn't one for the virgin cable service, as their modem communicates with the server/routers at their end. When you set up your account, I recall having to establish a connection, I think by sending them the MAC address or something similar. I think the modem is proprietary to Virgin cable.
Like I said, I’m curious to find out if there is another way
Old 16-07-2008, 11:01 AM   #3
7,713, Level: 20
Points: 7,713, Level: 20 Points: 7,713, Level: 20 Points: 7,713, Level: 20
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 69, Got 127
I dont think you can do this. It would be nice if VM made one themselves as i too hate having 2 boxes.
What i did was just hide the VM one away. I realise this doesnt really answer you question!
Old 16-07-2008, 11:16 AM   #4
8,575, Level: 22
Points: 8,575, Level: 22 Points: 8,575, Level: 22 Points: 8,575, Level: 22
Thanks: Gave 14, Got 38
Virgin Media do make a wireless modem router you have to call them up and order it from them, its not cheap tho!
Old 16-07-2008, 2:57 PM   #5
Thanks: Gave 49, Got 57
phone 151 and ask them. I would ask the question If I get wireless router/modem can I use it on the network if I give you the mac address of the modem.
When my modem broke they sent me a new one but it wouldnt work so I called them up they asked for the mac number on the bottom and with in 30secs it was up and running.
Old 16-07-2008, 5:34 PM   #6
5,391, Level: 17
Points: 5,391, Level: 17 Points: 5,391, Level: 17 Points: 5,391, Level: 17
Thanks: Gave 49, Got 48
there isnt a one box solution as said above
new customers on certain packages are offered a wireless router for free (netgear but with virgin branding)
its always worth a punt to see if they will send you one for free but as said it wont be a one box solution
