How simple is V+ compared to Sky+
Old 12-07-2008, 10:07 PM   #1
2,652, Level: 12
Points: 2,652, Level: 12 Points: 2,652, Level: 12 Points: 2,652, Level: 12
Thanks: Gave 0, Got 3
I've been seeing Sky advertising how simple Sky+ is to program and use.
I've got V+, and find it pretty easy to record stuff etc. How much easier is Sky+ ?
Old 12-07-2008, 10:31 PM   #2
2,758, Level: 12
Points: 2,758, Level: 12 Points: 2,758, Level: 12 Points: 2,758, Level: 12
Thanks: Gave 142, Got 67
Re: How simple is V+ compared to Sky+
I've never even seen a V+ box, but Sky+ is a doddle!I can't think how they could make it any easier to be honest. Very well thought out and logical to use. Mine is the newer Amstrad box, i've no idea if the older boxes are the same or different!
Old 13-07-2008, 9:06 AM   #3
Thanks: Gave 49, Got 57
diffrence include faster navigation on sky for one you also have a +24 hr and -24 hr button where v+ only has +24(next day) button so if you push the button twice you need to scroll back hour by hour.
Sky is much quicker and I belive sky can adjust the start time ie if football runs on the sky+ will start at the new time. I think I read somewhere v+ doesnt. Other than that both do the same job its just what you get used too.
Old 13-07-2008, 10:48 AM   #4
3,850, Level: 14
Points: 3,850, Level: 14 Points: 3,850, Level: 14 Points: 3,850, Level: 14
Thanks: Gave 43, Got 6
v+ advantages over sky are that it upscales any SD image to 1080i, which gives it much better clarity. It is slower to respond, though.
Old 13-07-2008, 4:30 PM   #5
17,164, Level: 31
Points: 17,164, Level: 31 Points: 17,164, Level: 31 Points: 17,164, Level: 31
Activity: 13.2%
Activity: 13.2% Activity: 13.2% Activity: 13.2%
Thanks: Gave 205, Got 346
Big advantage as far as I am aware is that V+ can record 2 programmes while you watch another whereas Sky+ can only record 1.
I do not know where this Sky+ is faster idea comes from, my (recently installed) V+ box is as fast as any of relatives/friends Sky+ or Sky HD boxes.
I can see no real difference in ease of use and PQ via HDMI on the V+ is certainly better. Also of course V+ can deliver real on demand services including BBCiPlayer C4OD etc direct to the TV.
A further advantage of V+ is that you do not own the box so should it go wrong VM fix it for free whereas with Sky you pay.
