V+ & sony htsf1300 AIO
Old 05-07-2008, 9:11 PM   #1
2,420, Level: 11
Points: 2,420, Level: 11 Points: 2,420, Level: 11 Points: 2,420, Level: 11
Looking to upgrade to v+ and wondered if the sony htsf1300 AIO would output 5.1 audio over hdmi (when broadcast) as there is no optical input on the receiver.
Old 06-07-2008, 10:40 AM   #2
1,966, Level: 10
Points: 1,966, Level: 10 Points: 1,966, Level: 10 Points: 1,966, Level: 10
Thanks: Gave 1, Got 12
Re: V+ & sony htsf1300 AIO
The HTSF1300 is supposed to have 2 optical inputs according to its spec on the Sony website, unless you mean you have no optical inputs spare:
http://www.sony.co.uk/view/ShowProdu...TechnicalSpecs
In answer to your question, the V+ will not output 5.1 through HDMI.
NB - The only channel on Virgin Media that seems to broadcast 5.1 is BBCHD.
Old 06-07-2008, 11:28 AM   #3
2,420, Level: 11
Thanks for clearing that up - I didn't think the v+ box could be connected to the "TV optical-in" connection on the sony, so relied on a hdmi connection only.
Presumably you connect the two boxes with a hdmi cable for video and an optical cable for audio if you want 5.1 from the BBCHD channel?
Old 06-07-2008, 11:43 AM   #4
1,966, Level: 10
Yep, that's right...
HDMI from the V+ direct to the TV (or to the amp if you're doing passthrough) for video. Then use optical from the V+ to the amp for audio.
Remember to turn on "HDMI audio overide" in the V+ settings.
