Help: What are the video outputs on a Virgin Media Samsung-2110C box?
Old 03-07-2008, 5:36 PM   #1
11,037, Level: 25
Points: 11,037, Level: 25 Points: 11,037, Level: 25 Points: 11,037, Level: 25
Thanks: Gave 2, Got 7
Question Help: What are the video outputs on a Virgin Media Samsung-2110C box?
I am about to hook up a friend's new home theater system. She has a virgin box Samsung smt-2110C. I want to take along the best cables to hook it up to her new Panasonic plasma when it arrives next week.
Can anyone help me out?
Does this box output via hdmi or something else? Which is the output for the best possible PQ?
I have Sky at home so dont know what Virgin offers.
Old 03-07-2008, 6:09 PM   #2
Ben Ben is offline
Ben's Avatar
6,398, Level: 19
Points: 6,398, Level: 19 Points: 6,398, Level: 19 Points: 6,398, Level: 19
Thanks: Gave 3, Got 265
Re: Help: What are the video outputs on a Virgin Media Samsung-2110C box?
RGB Scart is the best you'll get, unless you upgrade to the V+ which offers HDMI & component.
Old 03-07-2008, 7:55 PM   #3
11,120, Level: 25
Points: 11,120, Level: 25 Points: 11,120, Level: 25 Points: 11,120, Level: 25
Activity: 4.7%
Activity: 4.7% Activity: 4.7% Activity: 4.7%
Thanks: Gave 34, Got 120
As above, RGB SCART is the best you can get with the 2110. To even begin to appreciate the new plasma TV your friend should upgrade to V+.
Also there are no audio outputs other than via SCART so you wont be able to connect audio to an AV amp.
David
Old 03-07-2008, 10:26 PM   #4
Ben Ben is offline
Ben's Avatar
6,398, Level: 19
Pretty sure the SMT-2110C has optical. Not sure about analogue stereo though.
Old 03-07-2008, 11:40 PM   #5
malk's Avatar
3,305, Level: 13
Points: 3,305, Level: 13 Points: 3,305, Level: 13 Points: 3,305, Level: 13
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 90, Got 33
no optical buddy,scart is all its got.if you get a scart adapter ,then you can run it into an amp,thats what i did mate.them boxes are a bit poo really,at least the basic sky ones have stereo out!!
Old 04-07-2008, 7:27 AM   #6
2,679, Level: 12
Points: 2,679, Level: 12 Points: 2,679, Level: 12 Points: 2,679, Level: 12
Thanks: Gave 0, Got 3
The 2110 does have an optical output. The 2100 doesn't.
Old 04-07-2008, 9:22 AM   #7
malk's Avatar
3,305, Level: 13
Activity: 2.0%
yes you are right mate,i just found out mate.i was thinking of the 2100.
Old 09-07-2008, 4:08 PM   #8
2,312, Level: 11
Points: 2,312, Level: 11 Points: 2,312, Level: 11 Points: 2,312, Level: 11
dont worry bout the av sockets if you have a dvd recorder they usually have front and back right and left outs, hey presto surround sound
Old 10-07-2008, 4:41 AM   #9
4,236, Level: 15
Points: 4,236, Level: 15 Points: 4,236, Level: 15 Points: 4,236, Level: 15
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 5, Got 51
Not quite....
