Switching to Virgin from Sky - cabling question
Old 03-07-2008, 7:05 AM   #1
3,782, Level: 14
Points: 3,782, Level: 14 Points: 3,782, Level: 14 Points: 3,782, Level: 14
Thanks: Gave 3, Got 9
I've currently got Sky HD and for a number of reasons I'm switching to Virgin.
Question is we have a HD box downstairs and this is linked to the RF out to a TV upstairs with a magic eye, on top of that we also have a standard coax cable coming out of the standard sky aerial socket to feed a tv in the conservatory.
If we swap the sky box for a v+ box would we be able to use the existing cabling?
I know I will need a replacement magic eye thingumajig as well but was hoping to avoid any other costs
Old 05-07-2008, 10:17 AM   #2
7,713, Level: 20
Points: 7,713, Level: 20 Points: 7,713, Level: 20 Points: 7,713, Level: 20
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 69, Got 127
Re: Switching to Virgin from Sky - cabling question
there is someone on here who has had same problems try a few searches. I cant remember the exact outcome but i think you cant get a pic from RF and HDMI at the same time.
why not get a normal V box put in one of the other rooms? Its only £5 a month and means you should loose the charge for having the v+ box installed.
Mark
Old 05-07-2008, 8:47 PM   #3
2,652, Level: 12
Points: 2,652, Level: 12 Points: 2,652, Level: 12 Points: 2,652, Level: 12
Thanks: Gave 0, Got 3
Just wait a minute.
An extra V box is just £5 a month?
How much is a V+ box a month?
Old 06-07-2008, 4:33 PM   #4
3,782, Level: 14
Mark
Can you watch whats been recorded on the v+ box in one room with the V box in the other?
Can't find any info that says you can anywhere
Old 06-07-2008, 9:20 PM   #5
16,091, Level: 30
Points: 16,091, Level: 30 Points: 16,091, Level: 30 Points: 16,091, Level: 30
Thanks: Gave 38, Got 205
Not unless you use a screwdriver..
Old 07-07-2008, 10:49 AM   #6
7,713, Level: 20
Activity: 3.4%
No you cant. but if you have an extra standard box then you can watch 2 different channels in two different rooms (eg if your wife is watching some crap like Next top model when the football is on)
