3.5 million visitors each month
Go Back   AVForums.com > Digital TV Receivers and Services > Cable TV and Services > Virgin Media
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
Old 26-07-2007, 2:36 PM   #1 (permalink)
Thanks: Gave 0, Got 2
Media Center work with VM?
Moving house and might get VM. Would also like to build an HTPC. Does it play nice with VM? Do you miss out on anything this way - Video On Demand, etc., or does it all work nicely through the PC?
Anyone got experience witht his, and can tell me if it is worth bothering.
thelawnet is offline   Reply With Quote
Old 27-07-2007, 9:11 AM   #2 (permalink)
Mackem's Avatar
Thanks: Gave 5, Got 15
Re: Media Center work with VM?
If you mean using an HTPC instead of a Virgin Media box, don't think you can do this yet. You'd need a cable capture card, which the New Zealand spec version of my HTPC has but nowhere else, the last time I checked. I also think there's more to it than that. Have a look over on the computer forums but I've not seen anyone achieve this yet.
Philips 37PF9631 LCD, Telewest TVDrive, Panasonic S-49 DVD, Panasonic HS2 HDD/DVD recorder, Sony VGX-XL201 Media Centre PC, Logitech Z-5500 Home Theatre, PS3
Mackem is offline   Reply With Quote
Old 27-07-2007, 9:41 AM   #3 (permalink)
Thanks: Gave 8, Got 32
you can use a dvb-c card but don't expect interacive to work( ok moot point as it rarly works anyway) no virgin central or vod. just broadcast channels in the dvb-c standard,
you will also need the box key( which can be a real pain in the arse to get) for your and a nagavision cam emulator if your going to use your offical sub card. it's far easier to just use an illegal software l plug in to whatever dvb viewing software you use get all the channels.
Also it's the cable companies network and it's probably against the terms and conditions to use such anything but one of there boxes.
Ragnarok is offline   Reply With Quote
center, media, work
