Cheap and cheerful DVD rec for TVDrive
Old 27-06-2006, 7:51 PM   #1
4,781, Level: 16
Points: 4,781, Level: 16 Points: 4,781, Level: 16 Points: 4,781, Level: 16
Thanks: Gave 2, Got 2
Hi there,
I apologise in advance if this kind of thread had been posted previously, but can anyone advise on the best value for money DVD recorder that I can match up with my telewest TVDrive??
I am not especially looking for a really cheap unit but more a GOOD value for money unit.
Thanks in advance for your help.
Old 27-06-2006, 8:03 PM   #2
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
anything from the Panny (not E15) or Pio stable would be idea have a search as there was a member after one for ntl/Toopy combo recently. Make sure it has RGB scart inpt and remeber all recordings will be SD only
smario (29-06-2006)
