Harmony 360 and TVDrive
Old 27-06-2006, 2:41 PM   #1
SpookyElvis's Avatar
4,238, Level: 15
Points: 4,238, Level: 15 Points: 4,238, Level: 15 Points: 4,238, Level: 15
Thanks: Gave 30, Got 3
I've set up my remote using the Scientific Atlanta 8300DVB as my starting point. Problem is ,whenever I try using one of the PVR functions the screen starts stuttering until the action has been completed. Anyone know what I'm doing wrong? Thanks.
TCB
Old 29-06-2006, 11:39 AM   #2
4,238, Level: 15
Anyone?!?!
Old 04-07-2006, 3:02 PM   #3
8,253, Level: 21
Points: 8,253, Level: 21 Points: 8,253, Level: 21 Points: 8,253, Level: 21
Thanks: Gave 64, Got 225
Elvis
I've just got the Harmony 360 remote and set it up as Scientific Atlanta / TV Drive.
This setting doesn't add the PVR funtions to the remote, however by following the software and pointing the TV Drive remote at the Harmony, you can add all of the PVR functions to the corresponding buttons on the Harmony. I've done this and the PVR functions work fine.
Old 05-07-2006, 8:07 AM   #4
4,238, Level: 15
Thanks for that. Programmed all the remaining commands in last night-took nowhere near as long as I had feared. Even got it controlling the tower fan in the living room. Don't think I'll be leaving the couch anytime soon.
TCB
