How to control volume of Optical out on TVDrive?
Old 25-06-2006, 9:02 AM   #1
4,314, Level: 15
Points: 4,314, Level: 15 Points: 4,314, Level: 15 Points: 4,314, Level: 15
Thanks: Gave 6, Got 0
Hi Folks,
Is it possible to configure the Telewest remote control so that the volume buttons control the output level of of the optical out port? I have it connected up to a DD amp and I would like to use the TW remote to control the volume, instead of using the amp remote.
Thanks,
Kenny.
Old 25-06-2006, 9:17 AM   #2
11,279, Level: 25
Points: 11,279, Level: 25 Points: 11,279, Level: 25 Points: 11,279, Level: 25
Thanks: Gave 118, Got 63
Probably not - If you have the dosh I suggest you buy a learning remote that will "take over" being all your remotes.
Old 25-06-2006, 9:39 AM   #3
Cable Monkey's Avatar
18,572, Level: 33
Points: 18,572, Level: 33 Points: 18,572, Level: 33 Points: 18,572, Level: 33
Thanks: Gave 13, Got 252
Award-Showcase
Reducing volume digitally results in loss of resolution and so is not practiced normally. My Denon remote can mimick the TVDrive remote so I can get around it that way.
Old 25-06-2006, 9:53 AM   #4
the porter's Avatar
13,486, Level: 27
Points: 13,486, Level: 27 Points: 13,486, Level: 27 Points: 13,486, Level: 27
Activity: 7.1%
Activity: 7.1% Activity: 7.1% Activity: 7.1%
Thanks: Gave 240, Got 304
is
this one any good?
http://www.gladiatorcomputers.com/Pr...ink=TextSearch
Old 25-06-2006, 3:22 PM   #5
4,314, Level: 15
Thanks, but I already have a Kameleon universal remote and it refuses to learn some of the buttons on the TW remote. And I actually quite like the feel of the TW remote, but not having control of the volume is a bit of a pain. I wonder if I can get the TW remote to control My Pioneer DD amp directly? Is there a comprehensive list of codes somewhere?
Old 26-06-2006, 7:50 AM   #6
18,572, Level: 33
Award-Showcase
The TW remote is not a universal remote. It will only control volume and mute on TV's. Any codes available are published on the screen at: Blue button/settings and services/telewest help and info/tv/trouble shooting/remote control. There is a lot of good things said about the Harmony remotes, in particular that they can be updated via the web. I really think they are your best bet.
