Hi , i'm wondering what to do with this , i've got a z4 , all the ports on the back are full , both component , hdmi ,vga , svhs.......but.
I've recently hooked up my ntl box to my harddrive Liteon dvd recorder model 5045 , great piece of kit , i've gone ntl box rgb into liteon 5045 then svhs to my projector , due to both component ports been used by xbox 1 and ps2, but i don't use my xbox or ps2 as much these days , due to the 360 and pc etc , sooooooo my main question is , is it worth using a component cable on the dvd recorder , which is basically used for tv and not playing dvds , will i notice much difference going from svhs to component , but not forgetting that the main input is a ntl digital box via scart rgb............ is it worth the extra expenses? or is svhs as good as it needs to be for ntl digital...... i don't currently have a suitable lenghted component cable at present , so i would need to buy , is it worth the extra expense?!?!?!?!!?
Any advice welcome.....other than
