TVDrive and Harmony remote
Old 20-06-2006, 7:12 PM   #1
SpookyElvis's Avatar
4,238, Level: 15
Points: 4,238, Level: 15 Points: 4,238, Level: 15 Points: 4,238, Level: 15
Thanks: Gave 30, Got 3
Just a quick query. Anyone know the model no. of the TVDrive so as to get my Harmony 360 remote controlling it? Thanks in advance.
TCB
Old 20-06-2006, 7:51 PM   #2
3,484, Level: 13
Points: 3,484, Level: 13 Points: 3,484, Level: 13 Points: 3,484, Level: 13
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 13, Got 153
Im pretty sure you cant control the tvdrive with the harmony remote mate, its irda.
Sy
SpookyElvis (20-06-2006)
Old 20-06-2006, 7:56 PM   #3
11,279, Level: 25
Points: 11,279, Level: 25 Points: 11,279, Level: 25 Points: 11,279, Level: 25
Thanks: Gave 118, Got 63
The harmony remote works fine.
I can't remember the exact model name I put in - I used the name on the serial number thingy.
It didn't work properly.
However I went to troubleshooting and said I had the orginal remote and the clever thing told me it had a better match after I tested a couple of settings and sorted it all for me!
EDIT:- So it works, but I'm too thick to tell you the model number - perhaps someone could put me out of my misery aswell
Old 20-06-2006, 9:10 PM   #4
Saldawop's Avatar
10,326, Level: 24
Points: 10,326, Level: 24 Points: 10,326, Level: 24 Points: 10,326, Level: 24
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 184, Got 415
Will betting my Harmony 525 tomorrow ,hopefully . Took a test drive on the Logitech website and the TVDrive is listed .Scientic Atlanta>Telewest TVDrive .Obviously , not having the remote , I cannot say how it works.
Old 21-06-2006, 10:22 AM   #5
gerbilly's Avatar
11,727, Level: 25
Points: 11,727, Level: 25 Points: 11,727, Level: 25 Points: 11,727, Level: 25
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 40, Got 82
Scientific Atlantic Explorer 8300DVB
SpookyElvis (21-06-2006)
Old 21-06-2006, 2:42 PM   #6
3,601, Level: 14
Points: 3,601, Level: 14 Points: 3,601, Level: 14 Points: 3,601, Level: 14
Thanks: Gave 5, Got 9
I found with my 885 that it works best as a scientifica atlanta telewest tvdrive. I found the 8300DVB settings not as reliable.
Old 24-06-2006, 10:33 AM   #7
4,238, Level: 15
Sorry to drag this back up again. I've set up my Harmony 360 using Scientific Atlanta 8300DVB as suggested but when I use the remote the TV picture starts stuttering. This is when I use any button to control the TVDrive not just the PVR features. When I tried using my remote set up as Telewest TVDrive,as also suggested,only a few buttons have a response-none of which include the PVR controls. Any suggestions as to what I'm doing wrong. Thanks
TCB
Old 07-11-2006, 5:24 PM   #8
5,687, Level: 17
Points: 5,687, Level: 17 Points: 5,687, Level: 17 Points: 5,687, Level: 17
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 155, Got 29
Re: TVDrive and Harmony remote
TCB
did u ever manage to sort this problem, very tempted in purchasing this too
Old 07-11-2006, 7:19 PM   #9
miltsharman's Avatar
3,046, Level: 12
Points: 3,046, Level: 12 Points: 3,046, Level: 12 Points: 3,046, Level: 12
Thanks: Gave 18, Got 8
there is a tw 8300 option too I cant remember how i got it on the menus. but it is different to the SA 8300
Old 08-11-2006, 9:20 AM   #10
10,750, Level: 24
Points: 10,750, Level: 24 Points: 10,750, Level: 24 Points: 10,750, Level: 24
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 123, Got 160
Sy
The original STBs used IRDA but TVDrive does not. The Harmony should be fine
