TVDRIVE switching the outputs
Old 20-06-2006, 7:06 PM   #1
2,318, Level: 11
Points: 2,318, Level: 11 Points: 2,318, Level: 11 Points: 2,318, Level: 11
Thanks: Gave 10, Got 3
hi
I output my tvdrive via 720p component to my plasma.
I also send the signal upstairs via a scart video sender attached to the TVdrive's 'TV scart' socket. This works fine so far but it is a pain going to the telewest menu each time to switch output from component to scart.
I'm sure I read in one of the forums a while back that there was a hack the allowed you to switch sources quickly using the tvdrive handset.
I cant find the post that refers to this- does anyone know how its done?
Old 20-06-2006, 8:00 PM   #2
11,279, Level: 25
Points: 11,279, Level: 25 Points: 11,279, Level: 25 Points: 11,279, Level: 25
Thanks: Gave 118, Got 63
The signal is always outputted from the VCR scart, even when outputting HD via HDMI / component - the only downer is that the VCR scart outputs composite and not RGB, but at least you don't have to mess about with the menu stuff.
Hope this helps!
SlowRunner (20-06-2006)
