ntl videosenders
Old 16-06-2006, 6:00 PM   #1
standav
Posts: n/a
ntl videosenders
i have just had ntl cable installed in preference to sky . with the sky system i had a wireless videosender to a bedroom that worked perfectly. unfortunately it does not work with cable. can anyone suggest a videosender or system that will work with ntl, it seems that the set top box which is a new samsung silver box is the problem any advice will be warmly welcomed
many thanks
Old 17-06-2006, 1:13 PM   #2
3,333, Level: 13
Points: 3,333, Level: 13 Points: 3,333, Level: 13 Points: 3,333, Level: 13
Thanks: Gave 38, Got 39
Previously when I had NTL I used a Digisender Gold video sender as it was the only one which would cope with the NTL IR codes
