NTL Modem Direct Connection - MTU Failed!
Old 24-04-2006, 1:24 PM   #1
anchorless's Avatar
3,533, Level: 13
Points: 3,533, Level: 13 Points: 3,533, Level: 13 Points: 3,533, Level: 13
Thanks: Gave 12, Got 15
Question NTL Modem Direct Connection - MTU Failed!
Afternoon folks,
did a search but I couldn't find an answer to this so here goes...
my mate just got his NTL modem installed, so far all he's done is connect it directly to his Xbox 360 - when trying to connect to Xbox Live he gets an "MTU Failed" error. So far he's reset the Xbox network settings and turned to modem on/off. The modem has NOT been connected to a PC yet as his PC is poorly, has anyone got any idea why the MTU test is failing???
any help would be much appreciated
Old 24-04-2006, 1:45 PM   #2
5,033, Level: 16
Points: 5,033, Level: 16 Points: 5,033, Level: 16 Points: 5,033, Level: 16
Thanks: Gave 3, Got 154
Yep, seen it before. Its a fault with NTL, nothing to do with your set-up. Most of the time it just "goes away"
Old 24-04-2006, 1:48 PM   #3
anchorless's Avatar
3,533, Level: 13
bizarre. so you're saying me mate can't do get on Live until the problem "goes away"? will a call to NTL help dya think?
Old 24-04-2006, 2:30 PM   #4
5,033, Level: 16
Yeah get him to give them a ring. Its nothing he can do personally tho... you cannot change any settings in the modem, its in their network. I've seen it happen all day for some users, then next day its sorted.
Get on the blower to em and give em what for
Old 24-04-2006, 2:33 PM   #5
-Hitman-'s Avatar
9,365, Level: 23
Points: 9,365, Level: 23 Points: 9,365, Level: 23 Points: 9,365, Level: 23
Thanks: Gave 79, Got 140
If he's just had it installed then maybe it's because it has'nt been registered on the network yet!
Usually takes a few hours.
Old 30-04-2006, 8:50 AM   #6
4,303, Level: 15
Points: 4,303, Level: 15 Points: 4,303, Level: 15 Points: 4,303, Level: 15
Thanks: Gave 1, Got 0
hiya
i had a similar problem with telewest which i traced down to the mtu when live first came out years ago
what it turned out to be was a routing problem with the 82 range they had assigned me. u could try leaving the modem off for a few hours and switchin it on againt o hopefull get a new ip or quite often the cable company realises the prob and sorts it.
mgk
Old 25-11-2006, 8:35 PM   #7
GJC GJC is offline
GJC's Avatar
7,426, Level: 20
Points: 7,426, Level: 20 Points: 7,426, Level: 20 Points: 7,426, Level: 20
Thanks: Gave 104, Got 43
Re: NTL Modem Direct Connection - MTU Failed!
My brother has just tried to do this connection and he's also getting the same message.
NTL say they dont support Xbox Live He called them and they said he would have to go elsewhere
Are there any workarounds?
Old 25-11-2006, 9:04 PM   #8
geekydaz's Avatar
3,403, Level: 13
Points: 3,403, Level: 13 Points: 3,403, Level: 13 Points: 3,403, Level: 13
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 9, Got 19
The modem's connectivty will be restricted until it has been registered using your pin number, either using NTL's disc or by going to autoreg.autoregister.net. Although once it has been registered it may still have issues with passing the MTU test Don't know any workarounds, sorry.
Old 25-11-2006, 9:32 PM   #9
GJC GJC is offline
GJC's Avatar
7,426, Level: 20
Thanks for the info. I'll ask him to register tomorrow. What a shame NTL are'nt allowing sufficient MTU through there STB.....
Old 01-12-2006, 8:19 PM   #10
3,722, Level: 14
Points: 3,722, Level: 14 Points: 3,722, Level: 14 Points: 3,722, Level: 14
Thanks: Gave 14, Got 13
The easiest way to use the NTL cable modem with a Xbox 360 that I have found, was to use a cheap wired router (a LinkSys in my case) and register with NTL (via the router) using a PC, then connect the 360 via the router – this has worked without a hitch – with the added bonus that I have a basic NAT firewall in place too now
Ken B.
Old 01-12-2006, 10:08 PM   #11
Chris Muriel's Avatar
15,699, Level: 30
Points: 15,699, Level: 30 Points: 15,699, Level: 30 Points: 15,699, Level: 30
Activity: 11.1%
Activity: 11.1% Activity: 11.1% Activity: 11.1%
Thanks: Gave 510, Got 629
Exactly what I did when my son wanted Xbox live. ISTR it's a Linksys BEFSR41. Just cloned the Router address so that the WAN port appeared to NTL to be the same device as his previously directly connected PC network card.
Chris Muriel, Manchester
Old 13-12-2006, 10:32 AM   #12
6,823, Level: 19
Points: 6,823, Level: 19 Points: 6,823, Level: 19 Points: 6,823, Level: 19
Thanks: Gave 156, Got 217
For folks without a router, does spoofing the (registered) PC's MAC address work (go to Network Settings in the Xbox 360 dash and enter the PC's MAC address)?
Old 13-12-2006, 11:01 AM   #13
15,699, Level: 30
Activity: 11.1%
Cloning the MAC address should work in theory as long as you don't have the normally connected PC network card online at the same time.
