Originally Posted by Bruce Willy Did you have any issues with switching between MCE and Dscaler for timer recordings? |
Hmm, either I'm misunderstanding your question or you still not with me on how DScaler works!
DScaler and MCE should be viewed as being completely separate applications with no communication between the two. They need to be run separately and are controlled separately. It is possible to leave MCE open in the background and run DScaler at the same time but thats about it. Think separate!
So, no recorded programs, no use of the MCE remote to change channels, etc. (In fact DScaler has only a rudimentary record facility which is only a beta test so best to disregard at the moment.)
I still use MCE to listen to music, watch DVD's and view pictures but switch to DScaler to watch Sky. I use my Sky remote to change channels.
I should say here that if you use a different supported TV card, e.g. by Hauppauge, then Sky can be integrated into MCE a little bit better, e.g. MCE will change sky channels, can be viewed within MCE and can be set to record, BUT, only via Composite (S-Video if you have Sky+) and that was too poor a PQ for me to bear. And in this case DSCaler is no longer used.
HTH
Andy
