Telewest TV-Drive, Pronto etc
Old 12-04-2006, 9:07 AM   #1
sapper's Avatar
20,094, Level: 34
Points: 20,094, Level: 34 Points: 20,094, Level: 34 Points: 20,094, Level: 34
Activity: 19.3%
Activity: 19.3% Activity: 19.3% Activity: 19.3%
Thanks: Gave 432, Got 139
HI peeps,
I have an originial Pronto (T1000 US market) that is working well. However it never worked with the PACE Telewest infra red due to a subtle differeence in the type of infra red.
Has any one tried re-programming the new TV-Drvie with a programmable remote such as the Pronto.
Adrian
Old 21-04-2006, 1:25 PM   #2
4,937, Level: 16
Points: 4,937, Level: 16 Points: 4,937, Level: 16 Points: 4,937, Level: 16
Thanks: Gave 20, Got 33
It should work better then the Pace IRDA based boxes, try having a look at remotecentral.com for configs for the SA8300 (US equiv. of the TVDrive). Codes maybe different but the IR hardware should be the same.
Old 21-04-2006, 1:26 PM   #3
gerbilly's Avatar
11,727, Level: 25
Points: 11,727, Level: 25 Points: 11,727, Level: 25 Points: 11,727, Level: 25
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 40, Got 82
Works with my Harmony 655 and also 525. I had to make the remote learn each command though.
Old 21-04-2006, 1:29 PM   #4
sapper's Avatar
20,094, Level: 34
Activity: 19.3%
Oops...
I had forgotten i had started this thread.
Over Easter, I finally had time to teach my Pronto these codes, and it works fine...
At last one remote for all...
Adrian
Old 21-04-2006, 5:13 PM   #5
4,937, Level: 16
Figured you may have sorted it by now, was just seaching for "remote" and came across your unanswered thread.
