TVDrive in HDMI mode
Old 11-04-2006, 6:54 PM   #1
4,040, Level: 14
Points: 4,040, Level: 14 Points: 4,040, Level: 14 Points: 4,040, Level: 14
Thanks: Gave 1, Got 1
Just got my TVDrive installed and the lazy engineer just used the current SCART cable rather than pull out my sony 50"er , so I plugged the the HDMI cable in but I'm just getting a black screen when I select the HDMI port on my TV.
Any Ideas?
Old 11-04-2006, 6:55 PM   #2
the porter's Avatar
13,486, Level: 27
Points: 13,486, Level: 27 Points: 13,486, Level: 27 Points: 13,486, Level: 27
Activity: 7.1%
Activity: 7.1% Activity: 7.1% Activity: 7.1%
Thanks: Gave 240, Got 304
reset the tv drive box and also make sure youve set the tv drive box to hdmi 720 or 1080
Old 11-04-2006, 7:01 PM   #3
4,040, Level: 14
How do I set the HDMI on the tvdrive box?
Old 11-04-2006, 7:13 PM   #4
10,750, Level: 24
Points: 10,750, Level: 24 Points: 10,750, Level: 24 Points: 10,750, Level: 24
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 123, Got 160
its from the display and audio settings, press the TV Home button, the blue one and I think its the top right option.
Old 11-04-2006, 7:36 PM   #5
4,040, Level: 14
Cheers that worked, but I think I'll stick with the SCART for now as the picture on normal TV is terribly grainy especially at 1080i
Old 11-04-2006, 8:40 PM   #6
4,471, Level: 15
Points: 4,471, Level: 15 Points: 4,471, Level: 15 Points: 4,471, Level: 15
Thanks: Gave 10, Got 49
Try setting to 720p and using the hdmi again, I get a great picture on SD material that way.
Regards
John.
Old 11-04-2006, 9:33 PM   #7
4,040, Level: 14
Does all the HDMI mdes have a stupid black bands down the side of the screen? as if in 4:3 mode on move it to the left of the screen
