TVDrive and Harmony Remote Yet?
Old 10-04-2006, 3:00 PM   #1
Ecom
Posts: n/a
Does anyone know in the Telewest TVDrive remote has been mapped into the Harmony 855 remote system yet. Is anyone using one?
Old 10-04-2006, 6:48 PM   #2
gerbilly's Avatar
11,727, Level: 25
Points: 11,727, Level: 25 Points: 11,727, Level: 25 Points: 11,727, Level: 25
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 40, Got 82
Im using it with the 655 with no problems if you use the Scietific atlanta explorer 8300 dvb, and then learn each function individually it will work.
Takes a good 20 mins but worth it.
