Telewest TVDrive Layout
Old 04-04-2006, 8:02 AM   #1
4,264, Level: 15
Points: 4,264, Level: 15 Points: 4,264, Level: 15 Points: 4,264, Level: 15
Thanks: Gave 4, Got 6
Hi All,
I was wondering if someone could describe to me the layout of the back of the TVDrive. I am having one installed, but because I have quite complicated cable routing via my amp., I think I will have to run some cables before the engineer arrives. Could someone who has a TVDrive please let me know what connections ( ports ) are available at the back of the box and what type of power cable it uses ( i.e. is the power cable moulded into the box, or is it a 2-pin figure of eight type cable or a 3-pin kettle lead ). If anyone has a picture of the back then that would be ideal. I assume that the box has one HDMI output and probably a SCART socket, but what other phono type sockets are there ( RGB component etc, Video, Audio L, Audio R out ) and what type of digitial output is there ( Coaxial, Optical TOSLINK etc ).
Any help would be much appreciated.
Old 04-04-2006, 8:12 AM   #2
5,545, Level: 17
Points: 5,545, Level: 17 Points: 5,545, Level: 17 Points: 5,545, Level: 17
Activity: 3.9%
Activity: 3.9% Activity: 3.9% Activity: 3.9%
Thanks: Gave 73, Got 209
You can find an image on my site here . Click on the image for a bigger picture
regards
Brian
Old 04-04-2006, 8:23 AM   #3
4,264, Level: 15
That is exactly what I needed. Many thanks for that.
