what wireless video sender for NTL digibox?
Old 28-03-2006, 1:43 PM   #1
6,439, Level: 19
Points: 6,439, Level: 19 Points: 6,439, Level: 19 Points: 6,439, Level: 19
as topic - i recently got a lcd telly for the bedroom, and as a result i want to extend the ntl from the living room into there. I'm aware that lots of the normal wireless video transmitters dont send back the remote signals - has anyone got one they can reccomend? cheaper the better
Hugh
ps. i'm on an old-style ntl digibox (black job. pace i think)
Old 28-03-2006, 1:56 PM   #2
7,811, Level: 21
Points: 7,811, Level: 21 Points: 7,811, Level: 21 Points: 7,811, Level: 21
Thanks: Gave 2, Got 12
Well I use the One for All 1720 model for sending my Sky+ signal to a couple of different rooms. It sends composite & RGB and transmits the remote codes back.
I picked up mine for about £50 from ebay
Old 28-03-2006, 2:03 PM   #3
6,439, Level: 19
ahh the problem is that ntl/telewests remote use a higher frequency of ir (or something) so most transmitters do not pick it up.
*sigh*
Old 28-03-2006, 2:11 PM   #4
7,811, Level: 21
*sigh*
Do you know what frequency the cable IR uses? According to One for All's website the 1720 supports up to 60Hz
Old 28-03-2006, 3:16 PM   #5
IronGiant's Avatar
25,214, Level: 38
Points: 25,214, Level: 38 Points: 25,214, Level: 38 Points: 25,214, Level: 38
Activity: 29.1%
Activity: 29.1% Activity: 29.1% Activity: 29.1%
Thanks: Gave 2,347, Got 4,995
The Medion video sender from ToysRus works with NTL remotes. Unfortunately their website is out of stock at the moment, no doubt because they're only asking £9.99 for it at the moment (I paid twice that for mine!)
HTH
Dave
Old 02-04-2006, 8:13 PM   #6
Stokepotter
Posts: n/a
You need the AEI Digisender Gold (Used by myself) which allows upto 4 inputs & will also send the remote control signal. Rather steeply priced at approx £119 I believe but if you use it to its full capability well worth the money.
