V+ RF multi room
Old 18-11-2009, 3:45 PM   #1
4,933, Level: 16
Points: 4,933, Level: 16 Points: 4,933, Level: 16 Points: 4,933, Level: 16
V+ RF multi room
I currently feed standard RF through my sky box. this is then available to all the tv's connected via the distributed signal.
I am having a V+ box fitted, can this be done through the V+ box also?
Old 18-11-2009, 4:22 PM   #2
34,435, Level: 45
Points: 34,435, Level: 45 Points: 34,435, Level: 45 Points: 34,435, Level: 45
Activity: 99.7%
Activity: 99.7% Activity: 99.7% Activity: 99.7%
Thanks: Gave 78, Got 2,510
Re: V+ RF multi room
Not if you intend to use the HDMI output. If using HDMI then all other outputs apart from the VCR SCART and the optical audio out are disabled. You could use the output from the VCR SCART to an RF modulator in order to create a suitable signal.
Virgin Media in two rooms! HELP!
Old 18-11-2009, 4:25 PM   #3
4,933, Level: 16
Initially It'll just be Scart.
Not HD yet (until Mrs T lets me put a channel in to the wall for an HDMI cable to feed the TV)
Old 18-11-2009, 4:26 PM   #4
34,435, Level: 45
Activity: 99.7%
In that case, just use the RF output of he STB to feed the RF signal to other rooms and TVs.
