After deleting a recording it reappears the next day
Old 05-11-2009, 6:43 PM   #1
gblades's Avatar
3,732, Level: 14
Points: 3,732, Level: 14 Points: 3,732, Level: 14 Points: 3,732, Level: 14
Thanks: Gave 7, Got 57
I have a Samsung V+ box which I have had for just over a week.
On the 3rd I had a recording which went wrong and left an entry in the list of recordings which it sais is currently recording and 0h00 in length.
I have tried deleting it and even rebooting the box but after the reboot or overnight the recording comes back again.
Any idea how I can delete it permantly?
Old 06-11-2009, 1:48 AM   #2
telecom69's Avatar
3,056, Level: 13
Points: 3,056, Level: 13 Points: 3,056, Level: 13 Points: 3,056, Level: 13
Thanks: Gave 7, Got 11
Re: After deleting a recording it reappears the next day
The fact that it says 0h00 probably means that there is nothing there,try setting up a test recording then delete it, and see if that clears everything ....
Old 06-11-2009, 8:32 AM   #3
gblades's Avatar
3,732, Level: 14
The 0h00 seems to be normal on my box for when a recording is in progress. When recording once it has finished the 'NOW' changes to 'RECORDED' and then the correct duration is shown.
Its as if the planner got updated when the recording started but then wasnt updated when whatever went wrong and the recording stopped.
I have recorded, watched and deleted other programs and also deleted this offending entry a few times but the next day it is back again.
Its annoying as it causes the box not to go into standby and spin down the disk (its in a bedroom).
Old 06-11-2009, 9:36 AM   #4
2,648, Level: 11
Points: 2,648, Level: 11 Points: 2,648, Level: 11 Points: 2,648, Level: 11
Thanks: Gave 5, Got 13
i had this a year or so ago had to do a format to wipe everything and it cleared the problem if you haven't got much on your hard drive try it
Instructions On How To Format Your V+ Box
gblades (06-11-2009)
Old 06-11-2009, 9:49 AM   #5
gblades's Avatar
3,732, Level: 14
Thanks. Only got a few programs on there so will give it a go after the weekend when I have watched them.
