Originally Posted by freddyq Thinking aloud, could I re-arrange my setup so that I connect the switch to the main port and then the two PCs and D-Link to the switch? Will that work? |
Yes - that's essentially what putting to SuperHub into modem mode requires (just as if you had one of the older cable modems).
Your new router's external/WAN/Internet port is connected directly to the SuperHub (and configured to use DHCP to retrieve its IP address). Then you connect your PC's to the LAN/Intenal ports. Most router boxes, by default, will already be pre-configured with a static IP address (192.168.1.1, 192.168.0.1, or similar) and a DHCP service to allow your PC's to pick up an IP address, DNS server address and default gateway automatically.
