| Re: Help with router ?
The upside down ? mark is the internet light - the letter i with a circle around the bottom. When it's orange, it means it's not receiving info from the modem properly. This either happens when:
1 - You plug the modem into a lan port labelled 1-4 instead of the internet/wan port.
or
2 - You don't follow a logical reboot of your equipment as instructed after you physically connect it up.
Power the modem and router off, power on the modem first, wait for the lights to steady. Once they have, power on the router - your internet light should now be green and your PC will no longer have that 169 IP giving it 'limited or no connectivity'.
Should be in the first lot of instructions on the cd supplied which explains physical setup.
Toshiba 32C3030 HD LCD TV|360 Elite|Wii|DS|PSP|LG 22" M228WA HD LCD TV/Monitor|Linksys WRT54G + DD_WRT Gaming: 3.0ghz Intel Quad, 2GB RAM, 500GB HDD, Nvidia 9600GT 1GB SLI, XP Home. Design: Macbook 13.3", 2.0GHz iC2D, 320GB WD HDD, 4GB RAM, Leopard.
