AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Internet Service Providers (ISPs) > Virgin Media Blueyonder
LinkBack Thread Tools Display Modes
Old 26-06-2007, 9:18 PM   #1 (permalink)
J1mbo's Avatar
Thanks: Gave 0, Got 22
Newsgroup access
Anyone know how to set up newsgroup access on Virgin Media?
I found some website which indicated that it is possible to access newsgroups on Virgin without a third-party browser, but a call to tech support got me nowhere. They suggested I get my 'friends' to help set it up!!!
Just don't want to start paying for a newsgroup download manager thingy.
PS. I'm using a Mac, although I'm sure I can apply basic principles of what to do from Windows...
My sound gear - SQN 5S 5 channel Stereo audio mixer, Sennheiser 416 shotgun mic with internally cabled boom, 4 Audio 2020 radio sytems with Tram TR50 mics, Teletest 4.5" 16:9 LCD monitor and lots of other gubbins. And I can't afford a plasma 'cos of this lot!
J1mbo is offline
Old 01-07-2007, 5:34 AM   #2 (permalink)
Thanks: Gave 12, Got 29
Re: Newsgroup access
What do you want to use the newsgroups for, downloading binaries or participating in discussions? Depending on your primary use makes a bit of a difference with your choice of client.
If you've already picked a client out to use, then simply go to wherever you add the newsgroups server and use the address news.cable.ntlworld.com - you don't need a username or password.
Sorry if that's a bit vague... it's late (well, early) and I'm knackered! Let me know if you need more detailed info and I'll post when I'm a bit more awake
Edit: Oh - and port 119 if it asks (which should be the default for newsgroup servers anyway).
XBox Live / PSN: Retain81
Retain is offline
Old 01-07-2007, 2:02 PM   #3 (permalink)
chris57's Avatar
Thanks: Gave 4, Got 141
Go and have a read at either the grabit or alt.binz websites where there are tutorials.
If you are ex Telewest then the server name is news.blueyonder.co.uk on port119 3 connections if I remember rightly. I use Thundernews as Telewest newsgroups coverage was poor.
Sony KDL26S2030U, Popcornhour A100/A110 Network Media Tanks, Sumvision Aquaplus Enclosure, Phillips DVP-5960, Peekton 6006, Yamada 6700, PS3, Harmony 688
chris57 is offline
Old 16-07-2007, 9:07 PM   #4 (permalink)
Thanks: Gave 3, Got 22
Does that give access to usenet files like news.blueyonder.co.uk did with something like 3 day retention?
superal is offline
Old 26-07-2007, 8:45 AM   #5 (permalink)
Decadent Fool's Avatar
Thanks: Gave 25, Got 23
Yes, 3 days retention is about all you'll get, but hey, it's free !
Sony DDW-880 / TX32 / V+ hdmi/optical / 360 Arcade, Wii, GC Qoob Pro, DS Lite / Server: P4 2.8Ghz dual core-1TB-1500mb-ATI 2600Pro-Audigy 2 Platinum EX-MediaPortal / Girlfriend, half-Italian nurse
Decadent Fool is offline
access, newsgroup
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
