Thanks both of you, always good to know another view . . . I have a copy of MagicMovie Edit Pro17HD, but have been put-off by their "sign up and pay for AVCHD/mpeg4, with mpeg2 requiring a "free" registration as well. I've paid for the software, why can't they do their bit?
In my frustration I searched the HDD and found the download DVD-A , when run it seems to need Win XP SP2, Grief and this is only a year+ old (with Studio v10), which begs the Q when they wrote the "update" . . anyway it refuses to load, run or do anything useful.
Having so much free time means I could now try Windows Live Movie maker, since the W-DVD maker appears to stall on start-up.....(freezes after prodding). . . and I found I could Import my Vegas-Authored films into WLMM, then after it's had a further grind, it's ready for Saving - n Windows video format .WMF I think. After I've done this a few times I went back to DVD maker and that will import the Window files....(I wonder if it was re-rendering when it appeared to falter - unfortunately there is no "Action Bar" just a sill arrow going Round nad Round, which tells you nothing and makes it look like it's go stuck in a Loop.
After trying to force my Title on it, it has burnt a DVD, but it's confused about the Menu and Scenes - but forgive that, I do have a Playable DVD - I tried on two DVD players (one BD) and it seems to be accepted.
Not sure If I should try Magix - they constantly email me with Offers I don't want, and Registering might give them New Hope.
Vegas Studio Question:
1) If I only want to burn a DVD, can I Render in a format the Burner software will put stright onto the Disc, or is that expecting too much? I guess I'd not have the Menu, but maybe that can be inserted prior to burning, as I really only need text....
2) I find some moving titles are a tad "jerky" The use of keyframing seems to do this . . as I zoom in (making the text get larger), the letters have almost a drunken edge to them. Yet some transitions (of video) appear to move quite quickly without jagged edges. Is there a speed-limit for text, I wonder?
3) The same applies to Credit Roll - where some lines of text can jerk, yet I have little control over the speed, other than by stretching the event (etc.).
btw I set Vegas Studio v10 to match the incoming media 1920x1080x50i.
I'm having difficulty gettinig any sense from Vegas - you think they'd like to know if their "update" was Useful, etc.?
Far easier than recruiting new customers, already using another program . . . as it is, this "update" has wrecked my use of VS - & I'm waiting for that to go bad, too.
