Key Digital HD LEEZA HELP!!!
Old 08-11-2009, 1:19 AM   #1
1,381, Level: 8
Points: 1,381, Level: 8 Points: 1,381, Level: 8 Points: 1,381, Level: 8
I just got home with a brand new Sam Fuller Collection and want to watch some movies but someone has been screwing around with my scaler!!
I fired up the pj, turned on the player and all I see on the film screen is "DVI Searching"... for 15 mins. now!!
I've tried turning off the HD Leeza (to no avail mind you) and restarted both projector and Pioneer player multiple times. It doesn't even seem to be the case of the Leeza being on the wrong input because ALL of the blue lights on the front panel are flashing.
I can't even seem to access the main menu though, which is driving me insane! At least then I'd be able to double check that my inputs and settings are correct and make adjustments.
What can I do to save my movie night??
Is there a way that I'm not thinking of to force the menu screen as it won't normally pop up while "searching"... what should I do?
I hit the power button on the front panel since the remote is not even responding while searching and nothing happens. I hold it down and the blue lights dissappear for the duration that my finger presses ont he button, but as soon as I let go, they start flashing again.
Please help me!!
What happened to my scaler and how can I fix this... preferably in the next 30 minutes so I can enjoy the rest of the evening!
Thanks!!!
Old 08-11-2009, 1:55 AM   #2
1,381, Level: 8
Re: Key Digital HD LEEZA HELP!!!
the stupid granny button doesn't seem to be working and there's not a single damn button on the unit itself to bring up the menu or override the wrong input selection... how dumb is this?!?!?
I could kill the person who started screwing around with my system... they tried to play a cd and messed with my video scaler, arrghh!!!
