Get yourself a good graphics card. The feature set and processing on them, when set-up correctly, is almost up to professional VP standards.
Here's the relevant features on ATI HD4800 series and above:
· Hardware MPEG-1, and DivX video decode acceleration
· Motion compensation and IDCT
· ATI Avivo Video Post Processor
· New enhanced DVD up-conversion to HD
· New automatic and dynamic contrast adjustment
· Color space conversion
· Chroma subsampling format conversion
· Horizontal and vertical scaling
· Gamma correction
· Advanced vector adaptive per-pixel de-interlacing
· De-blocking and noise reduction filtering
· Detail enhancement
· Inverse telecine (2:2 and 3:2 pull-down correction)
· Bad edit correction
· Full score in HQV (SD) and HQV (HD) video quality benchmarks
· Two independent display controllers
· Drive two displays simultaneously with independent resolutions, refresh rates, color controls and video overlays for each display
· Full 30-bit display processing
· Programmable piecewise linear gamma correction, color correction, and color space conversion
· Spatial/temporal dithering provides 30-bit color quality on 24-bit and 18-bit displays
· High quality pre- and post-scaling engines, with underscan support for all display outputs
· Content-adaptive de-flicker filtering for interlaced displays
· Fast, glitch-free mode switching
· Hardware cursor
· Two integrated DVI display outputs
· Primary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI) or 2560x1600 (dual-link DVI)
· Secondary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI only)
· Each includes a dual-link HDCP encoder with on-chip key storage for high resolution playback of protected content
· Two integrated 400MHz 30-bit RAMDACs
· Each supports analog displays connected by VGA at all resolutions up to 2048x15363
· DisplayPort™ output support
· Supports 24- and 30-bit displays at all resolutions up to 2560x16003
· HDMI output support
· Supports all display resolutions up to 1920x1080
· Integrated HD audio controller with up to 2 channel 48 kHz stereo or multi-channel (7.1) AC3 enabling a plug-and-play cable-less audio solution
· Integrated AMD Xilleon™ HDTV encoder
· Provides high quality analog TV output (component/S-video/composite)
· Supports SDTV and HDTV resolutions
· Underscan and overscan compensation
· MPEG-2, MPEG-4, DivX, WMV9, VC-1, and H.264/AVC encoding and transcoding
· Seamless integration of pixel shaders with video in real time
· VGA mode support on all display outputs
Here's a report using the HQV test disc:
ATI Radeon HD 4870 X2 - AMD Back On Top - HotHardware
If you set up an ATI card with a good video player such as KMPlayer, and a fantastic rendering engine such as MadVR... you will get an absolutely superlative picture including SD playback.
The top NVidia cards are also very good.
