What format to use for vid on sd card in PANA txp46g10
Old 14-09-2009, 3:10 PM   #1
1,491, Level: 8
Points: 1,491, Level: 8 Points: 1,491, Level: 8 Points: 1,491, Level: 8
Thanks: Gave 2, Got 0
Anyone know what format I need to use for putting my HD film onto SD card to play on my PANA 46G10???
I know it plays DivX but can I use Mpeg4 ? Which is better
Many Thanks
Old 14-09-2009, 3:39 PM   #2
Conspicuous Member
choddo2006's Avatar
20,236, Level: 34
Points: 20,236, Level: 34 Points: 20,236, Level: 34 Points: 20,236, Level: 34
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 369, Got 613
Re: What format to use for vid on sd card in PANA txp46g10
divx is an implementation of one version of mpeg4.
The other type (h.264 or x.264) is sometimes just called mpeg4 as well (and is generally "better" and needs more horsepower to decode)
So it depends which you mean
bolov (14-09-2009)
Old 14-09-2009, 3:56 PM   #3
1,491, Level: 8
I have a 10 minute film made in HD
I wondered which format will:-
a: work on an sd card in my pana g10
and
b: look best ?
Old 16-09-2009, 5:52 AM   #4
3,967, Level: 14
Points: 3,967, Level: 14 Points: 3,967, Level: 14 Points: 3,967, Level: 14
Thanks: Gave 75, Got 36
I think this set will support AVCHD so I'd try that, multiavchd does a good job of converting most file types
Brian
bolov (16-09-2009)
Old 20-11-2009, 1:28 PM   #5
792, Level: 6
Points: 792, Level: 6 Points: 792, Level: 6 Points: 792, Level: 6
Hey,
I got my 46g10 yesterday, so was trying the exact same thing .
I used multiavchd like bferbrache said, it was really easy, you give it your source file (mine was video.mkv) then hit encode, a window pops up and you select viera output. It does its stuff and 5 minutes later outputs the required files for you.
Ill go in depth when i get home.
Old 16-08-2010, 10:44 AM   #6
803, Level: 6
Points: 803, Level: 6 Points: 803, Level: 6 Points: 803, Level: 6
Question Help!
Hi - i have the TX-P46G10B and I've tried using that program to convert an AVI file to mpeg4 (I selected one of the Viera output modes) but it still says 'No Valid File To Play' when I put the SD Card in my TV.I'm a relative newbie to this type of stuff - Can anybody tell me in idiots terms what to do to resolve this?Thanks a lot for any help you can offer!
