Is there a component->vga converter that can output a 50HZ vga signal?
Old 24-08-2009, 10:59 AM   #1
1,625, Level: 9
Points: 1,625, Level: 9 Points: 1,625, Level: 9 Points: 1,625, Level: 9
Thanks: Gave 2, Got 0
Question Is there a component->vga converter that can output a 50HZ vga signal?
Hello!
does anyone know of a component->vga converter that can output a 50hz vga signal if it detects a 50hz input?
What I am really looking is a device that can take the 576i/50hz signal from my ps2/xbox1/gamecube (all are PAL) and can output a 50hz vga signal (and not a 60hz) so that there is vsync and motion is smooth as it should be.
I have a vbox hd-360 right now , but it does not care of the input HZ, it only outputs 60hz , and makes motion jerky for those 50hz games...
thanks!
Old 24-08-2009, 12:35 PM   #2
Conspicuous Member
choddo2006's Avatar
20,236, Level: 34
Points: 20,236, Level: 34 Points: 20,236, Level: 34 Points: 20,236, Level: 34
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 369, Got 613
Re: Is there a component->vga converter that can output a 50HZ vga signal?
Most scalers can do this, you should be able to get a 2nd hand iscan or something.
Old 24-08-2009, 2:46 PM   #3
1,625, Level: 9
thanks choddo2006, can u be a little more specific? I am not familiar with models.. is there anything more to the name than iscan?
thanks!
Old 25-08-2009, 9:57 AM   #4
Conspicuous Member
choddo2006's Avatar
20,236, Level: 34
Activity: 0.7%
This would be perfect
DVDO ISCAN VP30 HDMI UPSCALER (NO RESERVE) on eBay (end time 27-Aug-09 19:33:14 BST)
That'll be up around at least 300-400 by the time it closes I'm sure
This would do the trick too, for less cash. I wouldn't pay more than about 100 for one of these, personally. In spite of the listing title, they don't do HD but should do VGA@50Hz I think.
SILICON IMAGE ISCAN ULTRA HD VIDEO PROCESSOR FOR PLASMA on eBay (end time 19-Sep-09 13:21:11 BST)
edit: yes, this datasheet from Anchor Bay Anchor Bay » Support » Documentation » Data Sheets says analog (VGA) output can be done on the iScan Ultra with 576line signals @ 31.25kHz line rate (625 total lines including overscan * 1/31250th of a second for each line = 1/50th of a second for a complete frame)
Edit 2: DickyDavis was selling one in the classifieds last month for £50, might still have it
http://www.avforums.com/forums/ampli...can-ultra.html
Old 25-08-2009, 12:05 PM   #5
1,625, Level: 9
thanks for the help choddo2006 , really appreciated!!!
