DVDO Edge IR port control
Old 19-08-2009, 10:26 AM   #1
2,696, Level: 12
Points: 2,696, Level: 12 Points: 2,696, Level: 12 Points: 2,696, Level: 12
Thanks: Gave 2, Got 3
Question DVDO Edge IR port control
Does anyone know if it is possible to control a DVDO Edge using the IR receiver port from a PC, say via a serial port?
Is there a spec available anywhere for the IR port?
Otherwise I guess I'll just have to use an IR transmitter to control it, although a wired connection would be better.
Alex
