AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Video Scalers, Video Processing and Progressive Scan
LinkBack Thread Tools Display Modes
Old 11-12-2007, 8:29 PM   #1 (permalink)
Thanks: Gave 50, Got 9
Radience audio question
I think I'm in a bit of a pickle. I am getting the Samsung Dual player when it is out next year. As well as HiDef video I would like the Hidef Audio also. I can't use my Rotel 1068 for that as the Sammy doesn't offer control of its 7.1 outputs and the Rotel doesn't do anything to those either. I had intended to get one of the new Onkyo receivers with 1.3a and support for the new audio formats.
But here is the rub. I also want the Radience to replace my Lumagen ProHDP. It will be 1.1 initially. So, I either output 1.3 into the Onkyo (and get Hidef audio) and then from there to the Radience (what will that do to the video - does it do passthrough?) or output the Sammy into the Radience and get 1.1 into the Onkyo - and no Hidef sound.
Is there a way out? If not, I could wait until the Radience is 1.3 but I feel I am always waiting and am sick of it. I'll probably just get the Radience and then upgrade when available and stick to SD audio in the meantime.
Martin
Barco Reality 919, Oppo 980, SkyHD, Lumagen Radience XD, Marantz AV8003, Rotel RMB-1095, Rotel RB-1080, M&K S-150 fronts and centre, M&K SS-150 sides and rears, Velodyne DD18, Vutech Vueasy screen and Mark Grant cables
Jonesthegas is offline
Old 12-12-2007, 4:11 PM   #2 (permalink)
Assured Advertiser
Liam @ Prog AV's Avatar
Thanks: Gave 3, Got 538
Re: Radience audio question
Ideally you want to run HDMI audio and video all via the Radiance, then send one of the two outputs to the amp. Does the Samsung thing support on-board decoding? The Radiance is able to pass through LPCM signals no probs. Seems with HD decks that the new norm is decoding in the player rather than passing through to the amp/processor for decoding.
PS - the Onkyo might have HDMI audio but I doubt it will compare to the sound quality of the Rotel pair. In fact mch analogue to the Rotel would probably sound better. I'd hurry into the Radiance and hold back on the audio until there are more options on the HD Audio processor side of things. (no point doing it the other way around - there ain't gonna be anything better than the Radiance for a bloody long time!)
call me: 01892 860801 / e-mail me: liam@progressive-av.com
Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers.
Ex-Demo Arcam fmj AV9, P7, DV139 - £3,350!!!
Liam @ Prog AV is offline
Old 12-12-2007, 7:52 PM   #3 (permalink)
Thanks Liam. The Samsung does have on board decoding (DTS MA needs a firmware update I believe) but for the HiDef stuff you can only output it via HDMI 1.3 or 7.1. I can't use 7.1 into the Rotel because it is a bypass mode ie it will not let you alter speaker delays. The Samsung should do this but it is a serious omission from the specs.
I did find out that the Onkyo has a passthrough mode for video so I could go from Samsung to Onkyo to Lumagen and wait for 1.3 upgrade to the Radience (date and cost unknown). Or I could just wait and stick to SD audio for the time being. I like my rotel stuff and am unsure what to do. The Onkyo does get rave reviews though.
I am not sure when we will see more 1.3 processors on the market. According to Nic Rhodes there are too many issues with the technology (mainly due to HDMI) for the major players like Arcam to get involved at this stage.
Martin
Old 14-12-2007, 3:32 PM   #4 (permalink)
Assured Advertiser
THat's a shame about the Samsung. Kind of makes having analogue outputs pointless if you can't balance them up correctly. Unfortunately as you have seen there just aren't many options in the HDMI audio market yet, it's only just started. It's such a tease knowing that something will be out there soon, but you have to face that if you want to be buying something today that we are just too early and will have to face a pick of the current limited crop of products available and/or not have full HD audio from every source.
audio, question, radience
Refbacks are On
Thread Thread Starter Forum Replies Last Post
tv/ps3/audio question toddmarshall LCD Televisions 2 11-11-2007 3:33 PM
Cambridge Audio 640R audio Question Mildoo Integrated AV Amplifiers and Receivers 2 26-10-2007 9:48 PM
Audio Question - HD-A1 HeweyBoy101 DVD Players (High Definition) 1 27-09-2006 10:33 PM
HD-A1 Audio Question dvdchild DVD Players (High Definition) 3 22-06-2006 7:05 PM
PS2 audio question Joe Pineapples PS2 5 16-05-2005 8:14 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
