AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Video Scalers, Video Processing and Progressive Scan
LinkBack Thread Tools Display Modes
Old 09-12-2007, 9:50 PM   #1 (permalink)
Thanks: Gave 5, Got 8
Can't make Sky HD output over HDMI to VP50Pro
Ok, I've got a strange one. I've spent the evening setting up my new PF10 - well, building a frame to strengthen the wall, very nearly dropping it when putting the panel into the mount etc.. Now, all seems to work fine, but I can't get the Sky HD box to output anything to the VP50Pro. Connected directly to the panel it works fine, but the VP50Pro sees nothing.
With my old panel, I used component rather than HDMI, so this is the first time I've tried to use the HDMI output.
Anyone got any tips or tricks - power on sequence, resets required etc.?
petes is offline
Old 09-12-2007, 10:37 PM   #2 (permalink)
Thanks: Gave 311, Got 311
Re: Can't make Sky HD output over HDMI to VP50Pro
Scalers can be grief - gotta make small steps.
Don't worry about what you CAN'T do - look at what you CAN do.
First thing is to get the scaler interfacing with the display. Can you you see the menu from the scaler?
Second thing is to get the scaler working with SOMETHING, anything. Start with composite and move up. Have you got a DVD player working through the VP50?
Need more information, Nick
welwynnick is offline
Old 09-12-2007, 10:43 PM   #3 (permalink)
Sorry - should have been more specific. Everything else was working (other HDMI, Component etc.) and output's fine - it was just the HD box. After much dicking around, it just started working - no real idea, and I don't think it was a different sequence, but it seemed to need, the scaler configured and on, the Sky power powered off at the mains, and then connect the Sky box. I guess it's reading the EDID when connected and not getting anything from the Scaler - bit of a chcken and egg.... Anyway, working now Thanks anyway.
petes is offline
Old 09-12-2007, 11:01 PM   #4 (permalink)
Sometimes you just need to switch the source on after the scaler, or something like that.
I'm intruiged about Sky HD plus VP50Pro. How does that look compared to a direct fed to the display? I would have high hopes for that combo.
Nick
Old 10-12-2007, 9:17 AM   #5 (permalink)
Nick
Huge improvement - PREP makes a big difference, and the scaling is of course a vast improvement. For a while last night, I had the HD connected directly to the display (whilst trying to work this out), and to be honest, the image was horrible - instant complaint from the wife about PQ on Strictly. However, the PF10 does have pretty basic scaling etc. compared to consumer panels, so with something like the PZ70B, the difference would probably be less marked.
petes is offline
hdmi, make, output, sky, vp50pro
Refbacks are On
Thread Thread Starter Forum Replies Last Post
VP50Pro 1.02 Beta firmware is out .... petes Video Scalers, Video Processing and Progressive Scan 3 14-12-2007 10:10 AM
VP50Pro to get Progressive Cadence Detection On/Off in 1.02 firmware kostas13 Video Scalers, Video Processing and Progressive Scan 2 28-11-2007 12:36 PM
Crystalio, Lumagen or VP50pro for Sony 70" SXRD JohnWin Video Scalers, Video Processing and Progressive Scan 10 30-10-2007 10:31 AM
Does Telewest TV drive support HDMI output via component as well as HDMI? Oogster Virgin Media 2 12-09-2006 6:46 PM
graphic card with HDMI output to samsung r74 LCDtv's HDMI chihangs Computer Systems 1 14-07-2006 11:48 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
