AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Video Scalers, Video Processing and Progressive Scan
LinkBack Thread Tools Display Modes
Old 09-12-2007, 6:11 PM   #1 (permalink)
jont's Avatar
Location: Now hanginaround Aylesbury instead of hanginaround Glasgow
Thanks: Gave 32, Got 204
dvi output problem with hdq and phd6
Have had to temporarily dismantle the cinema room whilst new carpet is going down ... have simplified the kit for a few days to skyHD, mac mini, hdq and plasma ...
problem is I can't seem to get the HDQ to output 768/dvi-d to the dvi input on the plasma ... it is stuck on 480p RGBHV ?
Have tried putting the direct menu 09322 and menu 025 but all this seems to do is throw the picture halfway across the screen and I cant see all of the menu to put it right (see pic) ...
Any help appreciated !!
thanks
Jon
my toys ... Arcam FMJ AV8, P7, DV27A+sdi | B&W 805s & HTM2 | Anthony Gallo Micros & sub | Sanyo Z4 | Samsung LE37R8 | SkyHD | Toshiba HD-E1 | Sony BDP300 | xBox360 Elite | Wii | AppleTV | iMac 3Ghz, MacBookAir (ssd) & MacMini | Nikon D300 & 17-55mm f2.8 | 3G iPhone
jont is offline
Old 09-12-2007, 6:29 PM   #2 (permalink)
Gordon @ Convergent AV's Avatar
Thanks: Gave 472, Got 972
Re: dvi output problem with hdq and phd6
Well according to the picture it's outputting 1366 x768 not 480p. I guess you are reading the ANALOGUE output which will be different from the digital output.....but you are using dvi out aren't you?
It just looks to me like you need to check the SIZ/POS of the plasma itself, then if the image still isn't centred you need to change the timing in the scaler to move it to the left.....you may need to use the service menu pos adjust in the plasma as well to get it all the way.
Gordon
Work: http://convergent-av.co.uk/about.html
My Photos: Flickr
My Blog:Do I know you?
Gordon @ Convergent AV is offline
Old 09-12-2007, 9:00 PM   #3 (permalink)
jont's Avatar
Gordon ... thanks for your help - have reset plasma in service menu and reset hdq now as well - will have a play over next few days and let you know how I get on !!
Catch up in a few weeks ...
rgds
Jon
jont is offline
dvi, hdq, output, phd6, problem
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Joytech Control Centre 540c Digital Audio Output problem with Xbox360 output dompotter Xbox 360 Hardware 6 17-05-2008 12:31 PM
Hi Deffinition output from console into PHD6 SillySausage Plasma Televisions 4 15-11-2005 1:42 PM
phd6/7 & scaler mthor Plasma Televisions 2 30-10-2004 5:35 PM
Panny PHD6 hutchys Plasma Televisions 1 26-09-2004 7:15 PM
PHD6 or PE30? gbrown Plasma Televisions 5 22-06-2004 11:47 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
