Lumagen HDQ - settings for SkyHD over component
Got my nice shinny new HDQ last week, installed and calibrated by Gordon using HDMI for HD and RGB for SD from the SkyHD box.
Given the warnings about using the HDMI connection, I've disconnected it which leaves me with the problem of needing to reconfigure it to use the component input.
For now I'll disconnect the RGB from Input 6 and replace it with the component connections but does anyone have a SkyHD over component config I can copy, as I assume this will be pretty similar for all SkyHD boxes?
Then when (if!) Sky admit the problem and fix it, I can just reload my saved config.
