AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Video Scalers, Video Processing and Progressive Scan
LinkBack Thread Tools Display Modes
Old 21-06-2006, 7:48 AM   #1 (permalink)
miceri's Avatar
Thanks: Gave 45, Got 62
Lumagen to AV Amp Connection
I see from the diagram on the DVDO site that all video sources should be connected to the HDP foe example. Yep, understand that.
HDP to Screen - Yup got that too
HDP to AV Amp - Why? I thought that you should separately then connect all audio source outputs to the AV amp. Thus letting the HDP process video, and the AV Amp process audio.
Is this connection setup the same as how I should wire the lumagen products?...
Have I got this wrong? I'm looking into the cable setup of running a HDP and don't want to replicate cabling if possible.
Cheers all //miceri
miceri is offline
Old 21-06-2006, 8:14 AM   #2 (permalink)
Gordon @ Convergent AV's Avatar
Thanks: Gave 472, Got 972
Your drawing for DVDo would result in no sound with Lumagen.
Lumagen have no audio routing capabilities. For optimum audio and video with Lumagen you should route video to scaler and audio direct to amplifier.
Gordon
Work: http://convergent-av.co.uk/about.html
My Photos: Flickr
My Blog:Do I know you?
Gordon @ Convergent AV is offline
miceri (21-06-2006)
Old 21-06-2006, 8:52 AM   #3 (permalink)
miceri's Avatar
Thats exactly what I though. But the DVDO picture has it connected to the amp.
I want to route all audio source directly to the amp. Should the lumagen be connected to the amp at all?
miceri is offline
Old 21-06-2006, 8:56 AM   #4 (permalink)
Ultima's Avatar
Thanks: Gave 401, Got 373
No, the DVDO is capable of routing audio, Lumagens are not. As Gordon said, route audio direct to the Amp.
Martin
Martin
AVF PS3 Fifa 2009 League - Stockport County
Ultima is offline
miceri (21-06-2006)
Old 21-06-2006, 9:02 AM   #5 (permalink)
miceri's Avatar
Perfect, the answer I wanted to hear - Thanks guys!
I'm now off to read the setup guide from the lumagen forum. I'm hoping to understand which cables to use for best effects (RGB / SCART / HDMI etc) so that I don' fork out on HDMI for AV Amp switching, and then later find that this is not the best solution...
Reason is that I will buy my intial setup of screen, amp, speakers, etc now. But for budget reasons the video processor later this autumn.
miceri is offline
Old 21-06-2006, 9:32 AM   #6 (permalink)
Thanks: Gave 1, Got 0
And so, the lumgens can't manage the delay between video and audio
Serge.
shacard is offline
Old 21-06-2006, 9:37 AM   #7 (permalink)
Ultima's Avatar
Serge.
Good point, presumably the Amp will need audio delay adjustment capablities.
Martin
Martin
Ultima is offline
Old 21-06-2006, 10:23 AM   #8 (permalink)
Assured Advertiser
Liam @ Prog AV's Avatar
Thanks: Gave 3, Got 538
If you wanna post all your sources here I'm sure someone will recommend best cabling
call me: 01892 860801 / e-mail me: liam@progressive-av.com
Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers.
Ex-Demo Arcam fmj AV9, P7, DV139 - £3,350!!!
Liam @ Prog AV is offline
Old 21-06-2006, 11:30 AM   #9 (permalink)
miceri's Avatar
If the lumagen doesn't offer audio support and the DVDO does, would it be better for me to user that. Note that I am a complete novice in this arena Any advice would be welcome.
The list of components that I am thinking of connecting is as follows:
Panasonic TH-42PX600
Denon AVR4306/3806/Yamaha RX-V2600
Pioneer DVDR-520H
Satellite/Cable HDTV (NOT Sky+ - I live in Sweden...)
Playstation2
Musical Fidelity A3.5/Primare I30
Arcam CD73
Monitor Audio GS20
Monitor Audio GS-LCR
REL Strata 5
(See attached)
How would I connect the transmission source (i.e. wall socket at present) so that it utilises both the analogue and digital tuners in the TV (Also the analogue tuner in the DVDR) in conjustion with the VP unit.
miceri is offline
Old 21-06-2006, 11:33 AM   #10 (permalink)
Assured Advertiser
No your AV Amp will handle audio for you. It will even give you a different amount of delay for each input, and means you don't have to be passing all your audio signals through the same box.
amp, connection, lumagen
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
