AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Video Scalers, Video Processing and Progressive Scan
LinkBack Thread Tools Display Modes
Old 20-06-2006, 6:07 PM   #1 (permalink)
Thanks: Gave 6, Got 26
HDCP help required
I've got an HDQ on the way and I'd like to be able to output native panel res (1366x768) at 50Hz via the analogue ports from SkyHD but can't because they've turned HDCP on on everything. Can anyone recommend a reasonably priced good quality stripper that doesn't perform any conversion (ie I want DVI or HDMI in and DVI or HDMI out)?
Tim
Arcam DV-88 | SkyHD | Squeezebox 3 | Intel Core 2 Duo E6600 & 2 x 7800 GTXs PC | Lumagen Radiance XD | Panasonic TH50-PHD8 | Meridian G68 | Audiolab 8000MX x 4 | Audiolab 8000PX x 2 | KEF 104/2 Raymond Cooke SE | KEF 100C | B&W ASW750 | KEF Reference Ci2000 rears | Calman Pro, i1Pro & Chroma 5
timmorris is offline
Old 20-06-2006, 7:05 PM   #2 (permalink)
Thanks: Gave 5, Got 63
Hi Tim,
Not sure why you can't do this via analogue as HDCP is not on the Component outputs from the SkyHD box. It may be a problem in the future
Stripper wise, you will be hard pushed to find any now. You can get some distribution boxes that allow a non-HDCP device to be connected to the 2nd output if the first is connected to a HDCP device.
Steve
Steve Richards
creative-av is offline
Old 20-06-2006, 7:14 PM   #3 (permalink)
I'm intending to use the YUV output for my bedroom telly by using a pair of CAT5 baluns.
Tim
Old 20-06-2006, 7:25 PM   #4 (permalink)
Ok - well the current advice from Gordon is not to feed the Lumagen's via HDMI from the SkyHD whilst the issue with them frying the I2C bus is going on!
Connect the SkyHD box via component to the Lumagen. This way there is no HDCP on the signal so the Lumagen will not disable the analogue outputs. I believe you can then can output via the DVI and analogue outputs.
Steve
Steve Richards
Old 20-06-2006, 7:37 PM   #5 (permalink)
That's fine for the time being, but eventually I'll need the component output from the Sky box to feed the bedroom. I've been offered a stripper but it comes in at about £270. I might just live with feeding the PHD8 720P.
Tim.
Old 20-06-2006, 8:01 PM   #6 (permalink)
loonatic's Avatar
Thanks: Gave 3, Got 17
Why not use a YUV splitter ?
JS Tech do one...
http://www.js-technology.com/product...7745285ffd62c7
...for £50.
Cheers, Lee
loonatic is offline
Old 20-06-2006, 8:14 PM   #7 (permalink)
I'm being Mr. Negative. Can't do that as both YUV/RGB inputs will be occupied.
Thanks for the suggestion though.
Tim
hdcp, required
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
