AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Video Scalers, Video Processing and Progressive Scan
LinkBack Thread Tools Display Modes
Old 20-06-2006, 4:39 PM   #1 (permalink)
Ultima's Avatar
Thanks: Gave 401, Got 373
Lumagen Vision DVI
Is the Lumagen Vision DVI a HD scaler??
I seem to have read somewhere that as a result of the latest firmware update that it can scale HD material in addition to SD. I can't find where I read this.
Am I totally wrong on this?
Martin
Martin
AVF PS3 Fifa 2009 League - Stockport County
Ultima is offline
Old 20-06-2006, 5:09 PM   #2 (permalink)
Thanks: Gave 3, Got 0
I noticed that too, I read it on the progressive av web site.
I was also wondering about the significance and if that now makes it a good buy compared with the HDP.
MozzaS is offline
Old 20-06-2006, 5:15 PM   #3 (permalink)
Thanks: Gave 6, Got 26
It can, but it only has 8 bit processing and it can only output 1080i not 1080P, whereas the HDP and HDQ have 10 bit processing and more inputs and outputs. The DVI cannot be upgraded to add analogue outputs or SDI inputs, the list goes on.
The best place to get answers is on the Lumagen forum (hosted by Gordon @ Convergent AV, the UK distributor).
http://www.convergent-av.co.uk/forum
I should add that Lumagen support is excellent with firmware updates being released every couple of weeks - they even have software in there that fixes problems with a number of DVD players, the new Tosh HD being one, and the CUE bug that my DVD player happens to suffer from. Only last week a guy from the UK had a problem which he posted on the forum and it was fixed inside 48 hours.
Tim
Arcam DV-88 | SkyHD | Squeezebox 3 | Intel Core 2 Duo E6600 & 2 x 7800 GTXs PC | Lumagen Radiance XD | Panasonic TH50-PHD8 | Meridian G68 | Audiolab 8000MX x 4 | Audiolab 8000PX x 2 | KEF 104/2 Raymond Cooke SE | KEF 100C | B&W ASW750 | KEF Reference Ci2000 rears | Calman Pro, i1Pro & Chroma 5
timmorris is offline
Ultima (20-06-2006)
Old 20-06-2006, 5:20 PM   #4 (permalink)
sdb123's Avatar
Thanks: Gave 562, Got 487
They're both options for the DVI. The one I have just purchased has the additonal analogue (BNC) outputs.
sdb123 is offline
Old 20-06-2006, 5:24 PM   #5 (permalink)
Apologies. I was typing from memory and I assumed that they couldn't be added. I know there's something else that can't be done but can't remember what. I'm sure Gordon will chime in when he gets a moment.
I've got an HDP on loan while I wait for my HDQ to be delivered and I've learned a hell of a lot about the replay chain, even going so far as to attempt an 11 point greyscale calibration myself.
Tim
Old 20-06-2006, 6:45 PM   #6 (permalink)
sdb123's Avatar
Tim
Well done!
sdb123 is offline
Old 20-06-2006, 8:54 PM   #7 (permalink)
Gordon @ Convergent AV's Avatar
Thanks: Gave 472, Got 972
DVI used to be retro-fittable with BNC and SDI. It's now not...it has to be pre-ordered with the parts up front.
Also SDI boards will no longer be available from 1st July.
For full differences see here:
http://www.convergent-av.co.uk/article3.html
Work: http://convergent-av.co.uk/about.html
My Photos: Flickr
My Blog:Do I know you?
Gordon @ Convergent AV is offline
Ultima (21-06-2006)
Old 21-06-2006, 10:27 AM   #8 (permalink)
Assured Advertiser
Liam @ Prog AV's Avatar
Thanks: Gave 3, Got 538
Vision DVI has per-pixel motion adaptive deinterlacing for 1080i as does the rest of the range. But the rest of the range also has cadence detection for 1080i film mode work. i.e. if a 1080i broadcast started life in 1080p, then the HDP/HDQ/ProHDP can regenerate the original 1080p25 frame where the VisionDVI would still emply motion adaptive which basically wouldn't be quite as sharp.
The difference on SD performance between the 8bit DVI and 10bit models is also quite noticeable. But there again, with the HDP at 50% more expensive again the DVI really is the bargain of the industry. Without doubt in fact. £825 for something that can handle SD and HD, and that has scaling that good is quite unbelieveable.
call me: 01892 860801 / e-mail me: liam@progressive-av.com
Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers.
Ex-Demo Arcam fmj AV9, P7, DV139 - £3,350!!!
Liam @ Prog AV is offline
Old 21-06-2006, 10:37 AM   #9 (permalink)
With 4 DVI inputs the HDQ is the one to look at for future proofing. It does cost almost double but If you want to hook up Sky HD (when they stop it breaking HDCP), and HTPC (you can send VGA over CAT5 now or even HDMI if you are prepared to pay) and an HD based DVD player that will take up three slots.
It also fits neatly under standard width equipment whereas the DVI and HDP are rather an odd size with gaudy looking graphics. The loan HDP I have while I wait for my HDQ (where is it btw Gordon? ) is on the floor, behind my rack using the IR pass-through of my Squeezebox to control it, because I couldn't find space for it. The HDQ will sit underneath my Sky HD box, leaving the rear of my equipment rack looking an awful lot tidier.
Tim
Old 21-06-2006, 10:40 AM   #10 (permalink)
Thanks: Gave 21, Got 67
I quite like the style of the DVI.. but then again I have plenty of space under the plasma for it
Lexicon,Anthony Gallo,Aurum Cantus,Velodyne
Matt Horne is offline
Old 21-06-2006, 10:44 AM   #11 (permalink)
I used to when I had the 42" plasma but I dropped the height of my rack and lost a shelf when I moved up to a 50. I've also just gone from a Meridian 561 to a G68, which in itself is a big mother! Now I don't have an HDP shaped hole!
Tim
Old 21-06-2006, 12:10 PM   #12 (permalink)
Thanks: Gave 5, Got 63
Only problem is the waiting list for the HDQ!
Steve
Steve Richards
creative-av is offline
Old 21-06-2006, 12:13 PM   #13 (permalink)
Has it grown again?
I've only waited since the beginning of April IIRC.
Tim
Old 21-06-2006, 12:28 PM   #14 (permalink)
Assured Advertiser
Steve
Depends who you go to and how well they have planned their stock intake....
Old 21-06-2006, 5:36 PM   #15 (permalink)
Now we know who ate all the pies Liam
Steve
Steve Richards
dvi, lumagen, vision
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
