AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Video Scalers, Video Processing and Progressive Scan
LinkBack Thread Tools Display Modes
Old 13-06-2006, 8:59 AM   #1 (permalink)
sdb123's Avatar
Thanks: Gave 562, Got 487
DVD Player to run through scaler and panel?
Hi all,
I will shortly be getting a Panasonic PWD8 and a Lumagen DVI scaler.
I am planning to connect the XBox 360 directly to the panel, Sky+ via Scart>4 RCA to the scaler.
My problem now comes with choice of DVD player. I currently have an Oppo, which I like however not entirely sure how it run with the proposed setup. I am considering going for a Denon 2900 (2nd hand) and wondered if this would work well via component into the scaler>panel?
I've posted a similar question in the DVD forum without reply thus far
I want to make full use of the kit I'll have, so any suggestions/alternatives are welcome!
Steve
sdb123 is offline
Old 13-06-2006, 9:02 AM   #2 (permalink)
Assured Advertiser
Liam @ Prog AV's Avatar
Thanks: Gave 3, Got 538
If you can get a 2900 at a decent price I would definitely take it. Awesome DVD player. Don't let the lack of DVI put you off either, in fact for this setup I would advise running analogue to the plasma too!!
call me: 01892 860801 / e-mail me: liam@progressive-av.com
Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers.
Ex-Demo Arcam fmj AV9, P7, DV139 - £3,350!!!
Liam @ Prog AV is offline
Old 13-06-2006, 9:10 AM   #3 (permalink)
sdb123's Avatar
Liam,
Thanks for the reply. It seems your are thinking along the same lines as me.
The Lumagen Vision DVI has the optional BNC Analogue Output fitted. I have ordered the appropriate BNC component input board and will be connecting the scaler to the panel with a RGBHV cable.
I have sourced a 2900 for a reasonable price too so am planning to buy that and connect via component to the scaler.
Does this sound okay? Following proper calibration should the picture be pretty good?
Steve
sdb123 is offline
Old 13-06-2006, 9:35 AM   #4 (permalink)
Assured Advertiser
You need the 5 BNC RGBHV input card on the Panasonic not the 3 BNC component one. Otherwise it all sounds fantastic. Recently did a Lumagen HDQ with Denon 2900 on a Panasonic 42PHD8 - lovely image. Will probably be the last SD DVD player that client will ever buy.
One thing, you mention PWD8... I would search Matt Horne's posts as he went SD, then got a scaler, then wished he had just gone straight for a HD panel (and a scaler).
Old 13-06-2006, 9:45 AM   #5 (permalink)
sdb123's Avatar
Hi Liam,
Yes, I've gone for the 5 BNC input card. Did my research on that one!
I've been in a bit of a dilemna over the PHD8 however I am sending Sky HD back and believe I'm making the right decision with this panel....
I'm sure I'll enjoy it anyway!
Steve
sdb123 is offline
Old 13-06-2006, 9:48 AM   #6 (permalink)
Assured Advertiser
Yes but even with SD TV and DVD the Lumagen can make use of those extra pixels on the PHD8.....
Old 16-06-2006, 8:34 AM   #7 (permalink)
sdb123's Avatar
Killer question time...just how much extra use will it make of the extra pixels of the PHD8 (in a theoretical % if possible)....will my eyes be able to tell the difference?
Steve
sdb123 is offline
Old 16-06-2006, 8:44 AM   #8 (permalink)
Thanks: Gave 5, Got 63
Steve,
Yes you will be able to see the difference. The PWD8 does a very good job of displaying SD and HD material but the PHD8 is another couple of notches up the scale.
Where are you located? Are you able to get to a dealer that has both on display so you can see for yourself?
Steve
Steve Richards
creative-av is offline
Old 16-06-2006, 9:00 AM   #9 (permalink)
sdb123's Avatar
Fat chance of that Steve....I'm in Bedford!
Unless you know of any within say an hours drive?
Steve
sdb123 is offline
Old 16-06-2006, 9:04 AM   #10 (permalink)
Assured Advertiser
I'm afraid to say only your eyes could put a figure on it, if at all. It's a qualitative thing rather than quantitive. As has been advised, secure yourself a demo (if you can!).
sdb123 (16-06-2006)
Old 16-06-2006, 9:06 AM   #11 (permalink)
Have AVLand in Wellingborough got any instock for a demo?
Steve Richards
Old 16-06-2006, 9:25 AM   #12 (permalink)
sdb123's Avatar
That'd be a no then!
sdb123 is offline
Old 16-06-2006, 9:39 AM   #13 (permalink)
What about dropping Piers of Home Cinema Engineering a line. He is based in Telford. That's only an hour or so from Bedford. He did have a PHD and a Lumagen setup.
Steve
Steve Richards
sdb123 (16-06-2006)
Old 16-06-2006, 4:58 PM   #14 (permalink)
Thanks: Gave 21, Got 67
Not entirely true.. more than happy with the PWD8.. glad I bought the scaler.. more than impressed with my hidef picture.. glad I saved a few hundred quid in the process
Lexicon,Anthony Gallo,Aurum Cantus,Velodyne
Matt Horne is offline
Old 16-06-2006, 9:13 PM   #15 (permalink)
Thanks: Gave 311, Got 311
I think a Denon 2900, Lumagen Vision DVI and Panasonic PHD8 with ISF claibration would be many people's idea of video heaven round here. Maybe not quite at the top, but very close to it indeed.
Good audio, too.
Nick
welwynnick is offline
sdb123 (16-06-2006)
dvd, panel, player, run, scaler
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
