09-06-2006, 11:38 AM
#1 (permalink)
Thanks: Gave 401, Got 373
DVDO HD+ VGA Picture Problem
I have connected my DVDO HD+ to my Samsung TV via DVI and it works fine.
However, I thought I would have a look at connecting them VGA to VGA and can't get a picture. I have made sure the HD+ is set to analogue output and the Samsung to PC input, tried all the output format options on the HD+ (Scrolling through them and selecting them that way) but can't get a picture.
I haven't changed any other settings so that may be my problem.
Any comments on what I should try would be much appreciated or do you need more info?
Regards
Martin
Martin
AVF PS3 Fifa 2009 League - Stockport County
09-06-2006, 12:24 PM
#2 (permalink)
Thanks: Gave 5, Got 63
Are you outputting a resolution that is allowed on the VGA port?
Steve
09-06-2006, 12:49 PM
#3 (permalink)
Steve
Steve, that's the problem, I have tried every pre-set output resolution on the HD+. The only thing that I haven't tried is any custom resolutions. But, how do I set a custom output resolution?
I am just downloading the Samsung Manual and will post the accepted resolutions.
Martin
Martin
09-06-2006, 1:11 PM
#4 (permalink)
Are you trying to display the output from a device that is connected to the Iscan via HDMI? If so then it would be an HDCP issue.
If not, have you tried changing the output signal to be progressive i.e. 720p you may also need to try changing the colour space for the Iscan to RGB and the panel to be RGB.
Steve
09-06-2006, 1:36 PM
#5 (permalink)
Steve
Steve, I have sky+ and a DVD Player attatched by component only, no HDMI.
I have tried 720p but I haven't tried changing the colourspace yet, I'll try that tonight.
Attached is the Samsung accepted PC connection resolutions. May have to look at the sync polarity settings as well?
I'll post further when I get home from work.
Many thanks Steve
Martin
Martin
09-06-2006, 3:27 PM
#6 (permalink)
Martin,
This was previously posted by HornyDragon:
http://www.dvdo.com/faq/faq_ishd.php#faq_hd3
see here, are you using H&V sync?
Also are you feedng the HD 720p from DVD or 576i/480i make sure the DVD player is set to interlaced output
It could be the H&V syncs.
Steve
09-06-2006, 3:32 PM
#7 (permalink)
Martin,
Steve
Steve, I think you are on the right lines with the H&V syncs as it says adjust these in the manual  RTFM seems appropriate  . I'll give it a try when I get home about 5.30. The output on the DVD player is interlaced ( AFAIK this model is not progressive anyway.)
I'll post results on H&V sync after I have played about with it.
Thanks for the pointers Steve.
Kindest regards.
Martin
Martin
09-06-2006, 3:37 PM
#8 (permalink)
No problem Martin.
Will look out for your post later.
Steve
09-06-2006, 6:49 PM
#9 (permalink)
Well, managerd to get a picture by messing with H/V sync settings but now have a problem with picture judder. Can't seem to find a setting at 50hz that works.
I think this will be a case of trial and error.
Will post finding as soon as I sort it.
Martin
Martin
10-06-2006, 7:58 AM
#10 (permalink)
Assured Advertiser
Thanks: Gave 78, Got 701
Hello ashworthacca
According to the table you link to you only have one Option (800x600) if your going in to your RGBHV (VGA) port at 50Hz.
Best regards
Joe
The Media Factory - Install, Connect and Control.
10-06-2006, 8:30 AM
#11 (permalink)
Originally Posted by Joe Fernand
Hello ashworthacca
Best regards
Joe
Thanks Joe, I'll give it a go.
Martin
Martin
10-06-2006, 10:42 AM
#12 (permalink)
Right I have settled on 1024X768 H+/V+ at 60hz. Slight judder on the ticker tape on sky sports but seems a better picture than I got from DVI at 720p.
I don't understand why or whether it's my eyes not adjusted to the new settings. Should it be better? Any views on this?
Also, I tried all settings and couldn't get a picture at 50hz, even 800x600. Will keep trying though.
Many thanks Steve and Joe for you help, it is much appreciated.
Martin
Martin
13-06-2006, 7:32 AM
#13 (permalink)
Update, after messing with the settings fro the last few days I can't get a signal at 50HZ therefore I am stuck with the slight judder problem.
However, I have got it working at 1366x768 H+/V+ at 50Hz unlocked 59.92 Hz and the picture quality is superb but the judder is bloody annoying.
Is it just my TV that won't accept 50HZ Locked? Are there any LCD TV's that do?
Regards
Martin
Martin
13-06-2006, 12:25 PM
#14 (permalink)
 Now judder free.
These are the settings I found that works for me.
Resolution: 1366x768p
Frame Rate: 60.00Hz
Line Rate: 47.700KHz
Sync: H+/V+
Thanks everyone for your help.
Regards
Martin
Martin
13-06-2006, 12:35 PM
#15 (permalink)
Great to hear that you got it working Martin.
I wonder why it will still ony accept a frame rate of 60Hz an not 50?
Steve
Steve Richards
