02-06-2006, 3:56 PM
#1 (permalink)
Thanks: Gave 1, Got 0
vga -> component
I want to convert the SVGA output from a pc to componemt (YUV) so it can be switched via my denon amp and does not require a second cable run to the plasma screen.
Quality isn't really an issue for what I want,
I can find a couple converters in USA which do this for around $100 which would be ideal.
anybody know of a uk site selling something like this?
sky+160,denon 3910, meridian G68, meridian G55, meridian G52 (bi-amp front) mission Elegante E83, E81, E8C, E81S, 37" panny 5 series
02-06-2006, 4:47 PM
#2 (permalink)
Thanks: Gave 5, Got 63
Why not just get a VGA->Component cable?
Steve
02-06-2006, 9:02 PM
#3 (permalink)
I don't think cable is enough. I have VGA-component cable and it doesn't seem to work with my laptop and plasma screen.
03-06-2006, 5:39 AM
#4 (permalink)
Assured Advertiser
Thanks: Gave 78, Got 701
Hello Mouth on Legs
I'd normally suggest Corioscan for a low cost PC to Video conversion solution but the models that offer you YUV are way more than 100.00 USD.
The entry level products all do Composite, S-Video and RGB PAL Out - its only the mid range (250.00 GBP+) units that do YUV Out.
Best regards
Joe
The Media Factory - Install, Connect and Control.
03-06-2006, 9:49 AM
#5 (permalink)
the pc VGA does not output a YUV compatable signal
I think this is the converter I need, but can't find a UK site
http://www.digitalconnection.com/pro...video/9a60.asp
I am a bit supprised I would have thought this would be an obvious thing to do, makes the switching easy (one knob on denon amp switches signal and sound, very WI-FE compatble (-_-)
03-06-2006, 10:29 AM
#6 (permalink)
looks like this may do the job any opinions?
http://www.marssystems.co.uk/proddetail.php?prod=xp_pro
standard pc out to component YUV pn panny 5 series
03-06-2006, 6:58 PM
#7 (permalink)
Assured Advertiser
Hello Mouth on Legs
It may make switching easy but it doesn't make for decent image quality - you said in your first Post that 'Quality isn't really an issue for what I want' which is handy because its definitely not going to look too hot!!!
A New Graphics card with YPbPr Out is more likely the best option.
Best regards
Joe
11-06-2006, 10:39 AM
#8 (permalink)
thank you for that, however I am struggling to find a suitable card, can you suggest any. it does not have to be state of the art, I am only using it for playing avi files and pictures, and itunes, no gaming or massive graphic processing required
11-06-2006, 12:58 PM
#9 (permalink)
Thanks: Gave 62, Got 217
Most of the ATI Radeon cards have an optional component out adapter (and support for 720p, 1080i native) - the 9800 certainly does have along with I think the 9600 (which can be had without a fan to make it silent)
Relysis 40 inch LCD, Harman Kardon AVR 630, MCPC (CM260, IMON, Tosh HDDVD-ROM, E2200@2.75GHz, 2400XT, 2GB, 320GB, Sweetspot SDI card,Happauge HVR4000, MCE'05), Kef XQ5/XQ2C/Q2DS/Q8S, Cyrus aca7.5, PSXR, CD6, Quad 303 x 3, Sky+ 250 SDI
