Toshiba Product Launch 2009
Old 15-03-2009, 5:34 PM   #1
AVF Editorial Manager
Phil Hinton's Avatar
106,654, Level: 79
Points: 106,654, Level: 79 Points: 106,654, Level: 79 Points: 106,654, Level: 79
Activity: 14.4%
Activity: 14.4% Activity: 14.4% Activity: 14.4%
Thanks: Gave 1,070, Got 4,185
AVForums.tv report from the Toshiba product launch 2009. On show are the company's high-end SV series of LED TV, new Dolby Volume technology and a few concepts for the future.
We hope you enjoy this production from the AVForums team. Please reply with your comments.
Options to view:Also you may subscribe to the MP4 (for your video iPod etc.) by clicking this button:
Old 15-03-2009, 10:11 PM   #2
Conspicuous Member
Crustyloafer's Avatar
32,647, Level: 44
Points: 32,647, Level: 44 Points: 32,647, Level: 44 Points: 32,647, Level: 44
Activity: 20.6%
Activity: 20.6% Activity: 20.6% Activity: 20.6%
Thanks: Gave 201, Got 1,228
Re: Toshiba Product Launch 2009
I have tried to sync this video podcast with my iPhone several times and keep getting the message that it will not be synced as it cannot be played on my iPhone.
Any ideas?
Old 15-03-2009, 10:39 PM   #3
Founder
Stuart Wright's Avatar
146,883, Level: 92
Points: 146,883, Level: 92 Points: 146,883, Level: 92 Points: 146,883, Level: 92
Activity: 18.2%
Activity: 18.2% Activity: 18.2% Activity: 18.2%
Thanks: Gave 902, Got 4,626
Originally Posted by Crustyloafer View Post
I have tried to sync this video podcast with my iPhone several times and keep getting the message tat it will not be synced as it cannot be played on my iPhone.
Any ideas?
What is the exact procedure you followed? I will try to replicate it.
Old 15-03-2009, 11:01 PM   #4
Illustrious Member
namuk's Avatar
40,920, Level: 49
Points: 40,920, Level: 49 Points: 40,920, Level: 49 Points: 40,920, Level: 49
Activity: 59.5%
Activity: 59.5% Activity: 59.5% Activity: 59.5%
Thanks: Gave 1,068, Got 2,470
Screens looking nice indeed .. need stop waching theses Dam wallet
top job HD via utube looking good....
Phil Hinton (15-03-2009)
Old 16-03-2009, 10:58 PM   #5
Conspicuous Member
choddo2006's Avatar
20,236, Level: 34
Points: 20,236, Level: 34 Points: 20,236, Level: 34 Points: 20,236, Level: 34
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 369, Got 613
I get the same. The Bristol Show video podcasts work fine. Others I've tried (65VX100 review, Panny launch and this one) all fail. Shame as catching up with these on the train is great.
According to Super(c) the encoding is quite different on the two. These are things which I'm not sure matter or not...
Toshiba;
AVC Format Profile: Main L1.3
res: 368x208
Audio sampling: 44.1KHz
Bristol Show;
AVC Format Profile: Baseline L3.0
res: 640x360
Audio sampling: 48KHz
I'm just trying to re-encode the Tosh one using settings as similar to the other as I can get them.... will let you know what happens...
Old 16-03-2009, 11:13 PM   #6
Conspicuous Member
choddo2006's Avatar
20,236, Level: 34
Activity: 0.7%
Yep, that works fine. After re-encoding, it seems to be:
Baseline L1.3
res: 640x360
Old 16-03-2009, 11:34 PM   #7
Conspicuous Member
choddo2006's Avatar
20,236, Level: 34
Activity: 0.7%
Well, doing it again at the original res and 44100 audio still works. So maybe it's that "Main" Profile that iTunes objects to sending to the iPhone?
Old 18-03-2009, 7:23 AM   #8
Conspicuous Member
32,647, Level: 44
Activity: 20.6%
There really isn't much of a procedure to syncing an iPhone. I have downloaded the podcast using the 'Get' button in iTunes.
The Toshiba podcast was downloaded successfully and plays fine in iTunes itself. However when it comes to syncing my iPhone with iTunes I get the following message.
Old 18-03-2009, 7:28 AM   #9
Conspicuous Member
32,647, Level: 44
Activity: 20.6%
I have just tried completely deleting my AV Forums.TV podcast subscription and then adding it back in again and I still get the same error with the Toshiba podcast.
Old 19-03-2009, 1:54 PM   #10
chic's Avatar
16,935, Level: 31
Points: 16,935, Level: 31 Points: 16,935, Level: 31 Points: 16,935, Level: 31
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 153, Got 884
i get the same error when i tried syncing it to my iphone
Old 19-03-2009, 11:19 PM   #11
Conspicuous Member
32,647, Level: 44
Activity: 20.6%
Is this going to get sorted out? Surely by now there would be a way of publishing the videos in one universal format that is consistently compatible with all iPod models.
Old 20-03-2009, 2:01 AM   #12
106,654, Level: 79
Activity: 14.4%
I don't have an iPhone, it works fine with my iPod classic. Stuart is looking at the iPhone issues. All videos are rendered the same within Sony vegas Pro.
Old 20-03-2009, 7:09 AM   #13
Conspicuous Member
32,647, Level: 44
Activity: 20.6%
Thanks for this Phil. It would seem from the quote below that there is a difference in the encoding used between some podcasts and others.
Toshiba;
res: 368x208
Bristol Show;
res: 640x360
Old 24-03-2009, 8:26 PM   #14
cooperda's Avatar
6,785, Level: 19
Points: 6,785, Level: 19 Points: 6,785, Level: 19 Points: 6,785, Level: 19
Thanks: Gave 48, Got 73
Like the features of these new Toshiba TVs - but then they go an stick an illuminated logo on the front!
Why do that!
Cheers, cooperda
Old 31-03-2009, 4:55 AM   #15
4,839, Level: 16
Points: 4,839, Level: 16 Points: 4,839, Level: 16 Points: 4,839, Level: 16
Thanks: Gave 3, Got 74
Why do that!
Cheers, cooperda
Another thing I notice is the reflected image of the poster behind Mr Andrew Line in the picture parts that should be dark.
Maybe difficult to judge from this video, how bad it is, but the picture surface seems rather reflective.
Old 25-05-2009, 10:08 AM   #16
1,674, Level: 9
Points: 1,674, Level: 9 Points: 1,674, Level: 9 Points: 1,674, Level: 9
Hi all,
I'm a new user so forgive me if I have missed a point somewhere.
When I get that message on itunes about not syncing a particular file I right click the item in itunes and get a list up on a pop up box one of which is "create ipod or iphone version".
If this is selected you will see itunes begin to convert the file. An icon pops up on the left hand menu with an orange motif that you can click to see the pogress of the conversion.
Once converted it will then most likely be displayed in your movies folder but may also occasionally appear in TV shows.
The file conversion takes a while depending on file size but can be left running minimized without too much detriment to using your PC.
I hope this helps as I upload lots of items from itunes for whiling away journeys and spare minutes and I often have to convert files to place them on my ipod classic.
regards
Baz
Old 16-06-2009, 11:16 PM   #17
Illustrious Member
Singh400's Avatar
32,635, Level: 44
Points: 32,635, Level: 44 Points: 32,635, Level: 44 Points: 32,635, Level: 44
Activity: 19.9%
Activity: 19.9% Activity: 19.9% Activity: 19.9%
Thanks: Gave 901, Got 2,138
Sorry for the bump, but I just saw Phil's post.
Gotta say this line up is looking brilliant. Am already very impressed with Toshiba, already own 2 of their screens (37WLT68 & 37RV555B) and I'm really looking forward to their SV line up.
That Dolby Volume is going to have a few problems I reckon. There's no way it can be 100% spot on when telling the difference between adverts and films/normal tv. Hopefully you'll be able to turn it off.
Old 19-07-2009, 5:41 PM   #18
Synchro's Avatar
12,703, Level: 27
Points: 12,703, Level: 27 Points: 12,703, Level: 27 Points: 12,703, Level: 27
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 143, Got 158
Dolby volume is great to see.
Great to see AVFORUMS are present in ZUNE Marketplace. ;-) Just subscribed to the podcast and I'll be listening every week now..
HTML code is On
