Best 40-42" 3D TV under £600?
Old 21-06-2012, 3:54 AM   #1
Hi guys,
I'm looking to buy a new TV for my bedroom - it'll be used for a mixture of gaming, Sky HD/3D and Blu Ray movies. I'd like something between 40-42" ideally.
I've had a good search on the Internet and through the forums but I don't seem to have come across a set that everybody agrees on. I know I can't expect anything amazing for my budget (< £600) but does anybody have any recommendations? Any special offers on at the moment maybe?
Thanks in advance guys, the help is much appreciated.
Old 21-06-2012, 6:20 AM   #2
Thanks: Gave 19, Got 1
Well I've just bought a 50" LG 3D tv for £500, bigger than you are looking for but shows the kind of thing out there. so there should be something out there for you and your budget.
Have you looked on the Richer Sounds website? Or Amazon?
Old 21-06-2012, 11:19 AM   #3
Scooby2000's Avatar
Thanks: Gave 1,677, Got 2,154
Panasonic 42"UT50 do a search online, be looking at 600-700...... Good place to buy http://www.amazon.co.uk/gp/aw/d/B007...LE&tag=iduk-21
Old 21-06-2012, 4:30 PM   #4
Thanks: Gave 33, Got 311
There seems to be a fan base building around a set produced by Cello using LG panels and marketed under several own brands for @ £300-£3120 as specials
