Originally Posted by ArmitageShanks Either way, there's no loss in resolution when a 3D mode is engaged on a 1080p image (all pixels are accounted for and the fine text is perfectly visible). The increased plasma dithering makes the very fine hash pattern a little less discernible than in 2D.
SBS and OU would obviously not render a 1920x1080 image. |
In fact passive can if OU is correctly encoded (as per the other thread on the subject).
Interestingly, your description of the grid lines (they're exactly 1 pixel wide) matches how they look on a passive set. It's a little bit of a cheat though since when viewing "Full HD" OU this way, if you close one eye then half the horizontal grid lines disappear
Of course, this may well raise discussions of when 2D can be 3D and when 3D is really 2D but all the same it does prove the set has the ability to resolve a single line (in 3D mode).
