Samsung SSG-3700CR 3D Glasses won't charge!
Old 16-03-2012, 7:10 AM   #1
Racquel Darrian's Avatar
Thanks: Gave 99, Got 125
My glasses went off yesterday as the power needed charging up again.
Thing is it won't charge at all. No lights come on when I insert the power usb cable. I left it on over night anyway and it's still dead.
I've tried turning the 3D on via the TV with the power usb inserted too, and no sign of life at all.
Has anyone got any tips?
Old 16-03-2012, 2:13 PM   #2
Thanks: Gave 5, Got 36
Try pressing reset button next to usb input, after plugging in
Racquel Darrian (16-03-2012)
Old 16-03-2012, 4:21 PM   #3
Thank you, you're a life saver!
I didn't even know there was a reset button at all.
Just to note: It didn't work with it plugged into the USB wall socket but it did work with the USB on my laptop.
Old 19-06-2012, 2:06 AM   #4
Where is the reset button?? I can't find one
Old 19-06-2012, 8:18 PM   #5
There is a circular hole next to the usb input. Pres and hold down switch licated within.
Old 03-05-2013, 7:20 PM   #6
Thanks: Gave 3, Got 8
My pair of 3500CR and 3300CR glasses stopped charging and I came across this thread, just needed to say THANK YOU!
Saved me buying new ones! And hope this thread can help someone else too.
