Originally Posted by scurlock1982 Do you game on it? Been reading that image retention is anoying on plasmas. |
Im a BF3 player and only use plasmas. Plasma get IR but most the time it goes quite quick. Plasmas need to settle when new so you just take it easy for around 200 hours, maybe game upto an hour then watch some tv for a bit. After the sets are run in IR isnt much of an issue. Also dont confuse IR with burn, IR is temporary. You shouldnt game for too long without a break anyway but I can safely say the odd 4-5hour sesh is ok on a run in set, you may get a bit of IR but its quite mild and will go over time. If you like playing FPS I think youll appreciate the low lag on the D6900 or lower end Panasonics. Only thing really wrong with the D6900 is it doesnt perform well in a bright room, otherwise its fantastic.
Just to add, I like the glasses with this set too, nice and light, better than the Panasonic glasses IMO.
