Hello, I thought I would pop back here because I made a little adjustment to my program recently (due to a HD failing).
E.G. The first 30-ish meg on my HD has failed, so I used 'Disk Managment" loaded via Run > "compmgmt.msc". And created 2 partitions 1st is 40 MB and the 2nd is the rest of the disk space. Then deleted the 1st small partition. Then format it again in the TV. (get your breath)
The program now checks all 4 of the primary type partitions instead of just the first one(-ish). File Attached.
I'll try to answer some other questions here?
Originally Posted by Teflon The programme tells me to "select the drive to adjust the performance byte", but no drives are shown. |
Hmmm, you will probably have to run the program "Run As" "Administrator". That should help.
Originally Posted by buzza_2004 it has worked fine since xmas however its just stopped being recognized by the tv (d6530). |
I had the same problem!, the only way around it I found was to fully format the Drive again. But you might want to consider that the drive if failing too?
write speeds of 30mb/s....will this be sufficient do you think??
I believe it should be enough for real (
from my point of view, because 20mb/s should be enough), but I think the TV will not like it! - thats only a complete guess!
Originally Posted by ademey I try this in Linux (Ubuntu) and get the error: Does not appear to be XFS drive\partition. I have ES5500 series tv and a Kingston Data Traveler G3 |
Sorry I dont know what type of type system the ES5500 uses?. My only suggestion it to show all hidden/system files, and browse for files with PVR, Chk or Log in the name. (or something similar)
Then look in the file to see if the values could be change to some sort of positive value?
(Just to double check) did you select the correct drive. e.g. try "sda", "sda1", "sdb", "sdb1", "sdb2" etc...
