Nanite
Established Member
- Joined
- Jun 25, 2010
- Messages
- 145
- Reaction score
- 21
- Points
- 20
3D Plasmas seems to have good 3D performance. The only problem is crosstalk in dark background scenes at least in Samsung models.
Lets gather performance results from our TVs
Download this side-by-side L-R 3D video:
3D_crosstalk_test_1080p_SBS_L-R.mp4 - File Shared from Box.net - Free Online File Storage
- Place it on USB stick, put the stick on TV and play it. Panasonic VT owners needs to play it from other external device (BD player) to be able to enable the 3D mode.
- Enable 3D and choose the side-by-side mode and open 3D glasses.
- In the middle of the video press pause.
- First close your right eye and write the smaller number which is visible on the top half screen and then write the smaller number which is visible on the bottom half screen
- Do the same procedure then with the left eye closed.
.MPO 3D still picture version of the image from the video which can be downloaded here:
http://dl.dropbox.com/u/7350380/testpattern.mpo
The side by side jpeg can be downloaded here:
http://3dfrank.com/testpattern.jpg
You can play .MPO 3D picture files with PS3 'Play Memories' program available free from PSN.
Panasonic plasmas can play this from memory stick.
Example how you can answer:
3D TV model: Samsung PN50C7705 50" Plasma
3D glasses model: Samsung original battery powered.
Left eye open/right closed -> top half screen smaller visible number -> 1
Left eye open/right closed -> bottom half screen smaller visible number -> 3
Right eye open/left closed -> top half screen smaller visible number -> 3
Right eye open/left closed -> bottom half screen smaller visible number -> 1
If you can't see the top/bottom half screen you must answer:
Left eye open/right closed -> top half screen smaller visible number -> 4
Left eye open/right closed -> bottom half screen smaller visible number -> NOTHING
Right eye open/left closed -> top half screen smaller visible number -> NOTHING
Right eye open/left closed -> bottom half screen smaller visible number -> 5
With this crosstalk test we can measure how good performs each set 3d tv/3d glasses with dark bakground scenes.
The best possible results for crosstalk are:
...Shamelessly copied this topic from other forum that lies in the dark corner of the internet to get more results.
