40" Samsung, Sony or Toshiba??
Old 26-05-2008, 8:46 PM   #1
5,204, Level: 17
Points: 5,204, Level: 17 Points: 5,204, Level: 17 Points: 5,204, Level: 17
Please could someone tell me which one of these TV’s you think would be best for watching DVD’s and Playing Xbox 360?
Samsung LE40A556P
Sony KDL40D3500
Toshiba 40XF355DB
Thanks.
Old 26-05-2008, 8:59 PM   #2
5,828, Level: 18
Points: 5,828, Level: 18 Points: 5,828, Level: 18 Points: 5,828, Level: 18
Thanks: Gave 5, Got 361
Re: 40" Samsung, Sony or Toshiba??
Having a Samsung for about 11 months, I wouldn't recommend another one. The features are great, as are the actual panels. But the electronics and firmware behind them are lousy. When I upgrade to Blu-Ray my M86 will be unwatchable (24hz hum bars) also with PAL.
Old 27-05-2008, 6:46 AM   #3
ChrisGgr's Avatar
210,527, Level: 100
Points: 210,527, Level: 100 Points: 210,527, Level: 100 Points: 210,527, Level: 100
Thanks: Gave 897, Got 1,655
I have to agree that thats exactly the problem with samsung.Their PQ is great but the electronics inside are problematic as bob says.Between the other two I usually suggest the 40V3000,so as a change I suggest you the 40XF355 as its also an excellent set with slim bezel too.The only worrying thing is the common backlight bleed issues
