Best Current 37/40" LCD around £700
Old 19-09-2009, 7:26 PM   #1
4,480, Level: 15
Points: 4,480, Level: 15 Points: 4,480, Level: 15 Points: 4,480, Level: 15
Thanks: Gave 11, Got 1
Hi everyone,
Any thoughts?
It will be used for Sky HD alone and lots of football
Thanks for your time either way.
Chris.
Old 19-09-2009, 8:45 PM   #2
24,805, Level: 38
Points: 24,805, Level: 38 Points: 24,805, Level: 38 Points: 24,805, Level: 38
Activity: 66.2%
Activity: 66.2% Activity: 66.2% Activity: 66.2%
Thanks: Gave 94, Got 1,299
Re: Best Current 37/40" LCD around £700
Panasonic 37x10 plasma, 720p HD ready but excellent for sport and TV (HD isn't 1080p). I am watching ESPN hd now on my previous gen model, very good
http://www.johnlewis.com/230563560/Product.aspx
If you want a full HD set, make sure you get 100hz, look at the Panasonics, Samsung 40b650 or Sony 40w5500 (might be slightly over budget)
Old 19-09-2009, 8:49 PM   #3
4,480, Level: 15
after looking around a bit, is the samsung le40b650 a good shout...
also why are people saying the 37" version is worse?
Old 19-09-2009, 8:51 PM   #4
24,805, Level: 38
Activity: 66.2%
They use non-Samsung panels, different type (same for the Sony 37s) - the 40" panels are made by the manufacturers
Old 19-09-2009, 8:51 PM   #5
ChrisGgr's Avatar
210,527, Level: 100
Points: 210,527, Level: 100 Points: 210,527, Level: 100 Points: 210,527, Level: 100
Thanks: Gave 897, Got 1,655
because it uses a different panel(lower quality).The same applies to 37W5500,so it d be better to stick with the 40B650/40W5500.Both around the budget!
Old 19-09-2009, 8:51 PM   #6
4,480, Level: 15
Thanks Vickster, we must have posted at the same time.
I will check out the set / makes mentioned. I love this site it's so helpful.
Old 19-09-2009, 8:57 PM   #7
4,480, Level: 15
Thanks Chris too for the info
